Question about HP Pavilion a305w (DM181AR) PC Desktop
Insides are unhooked
I need a picture or directions on what to hook up where on the inside of my computer.
    Scholar:
  • 135 Answers
Everything in a modern computer can either only fit into one place, are numbers and can ALWAYS only fit one way. Except very old IDE cables (ribbon like).
follow this link for a nice tutorial :
http://www.digitgeek.com/how-to-assemble-and-build-a-pc/
Posted on Dec 12, 2008
I have a nissan maxima ,and i think i shorted something out ,while hooking up the radio,which in turn the car wont turn over and have a buzzing sound from inside the auto
First I would unhook the radio. Some of the wires to the radio are communication lines. Put power to the wrong wire and it can burn out computers.
Jul 24, 2016 | 2001 Nissan Maxima
Wont turn off a/c still works
You have to take the cover off and get inside and unhook a wire. You may have 3 wires unhook 1 and if that doesn't turn it off hook it back up and unhook the next. One of them will turn it off!! Then go to the hardware and get another thermos!! You won't get a shock or anything cause it's not hooked up to any power source, they are just sensor wires. I don't know much about Honeywell, I just know I don't like their thermos. Had one once and had nothing but trouble w/it !!
Jul 27, 2014 | Honeywell RTH230B 5-2 Day Programmable...
Car was off...parking light, tail light, and directional arrow inside came on and wont turn off?
Maybe the battery inside key fob needs changing. It sounds like its to do with the alarm / immobiliser.
Mar 11, 2014 | 2001 Mitsubishi Montero
OK when I got the amp someone had taking it apart and I'm trying tohook up the wires they were all unhooked on the inside of the amp And I Can t figure out how it hooks up the amp is a G80 XL
Can you forward me a picture of the amp? I can tell you exactly where the wires go. I am an authorized Crate repair center.
keyboards0822@hotmail.com
Sep 13, 2011 | Audio Players & Recorders
ABS LIGHT STAYS ON. WHAT DO I NEED TO REPLACE TO CORRECT THE PROBLEM? THIS IS 1997 GRAND CHEROKE
you can have a mechanic put it on his computer and clear it or unhook your battery cable and hook it back up to reset it, if it comes back on after driving the abs ( anti lock braking system ) may not be working could be bad sensor or dirty wheel hubs on the inside of your hubs in the front that is where the sensor is located.
Sep 24, 2009 | 1997 Jeep Grand Cherokee
Moultrie mfh-i-40 white wire inside is unhooked on one end what does it hook too
DON'T WORRY ABOUT IT...IT'S NOT SUPPOSED TO BE HOOKED UP....ANTENNA FOR REMOTE CONTROL OPTION
Aug 20, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I want to hook up a trailer to my truck. I notice there are "extra" outlets or something at the rear. Are these there to hook to?
any extra outlets would only be used depending on how your`` trailer is optioned.do you need a brake controller?do you have back-up light?do you need to charge a second battery?these would be the only reason to need the extra plugs.
Jul 29, 2009 | 2001 Chevrolet S-10
1995 Toyota Camry drivers side door latch unhooked
On the metal rod that runs vertically up to the door handle, there should be a large yellow clip that holds the rod onto the handle. These break with regularity, look at the bottom of the inside of the door shell to see if it indeed has broken & fallen down.
Sep 13, 2008 | 1995 Toyota Camry
Inside door handle
Remove the two screws in the arm rest pocket. Carefully pry around the bottom edge of the upholstered panel to release nylon stud & socket fasteners. Remove triangle trim panel at forward edge of window by prying loose the same fastener in the middle of that panel...lift upwards to remove. Lift the entire panel to unhook the top edge which hooks over the sheetmetal at the bottom of the window opening. The trim around the doorhandle is held in place by three three j-hooks which must be pressed towards the center of the handle to release. The door handle assy simply slides forward about 1/2" before coming loose from the metal in the door. You can buy extra stud & socket assemblies at a chev garage for pennies
Aug 27, 2008 | 1998 Chevrolet Tahoe
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
wg
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
HP Pavilion a305w (DM181AR) PC Desktop Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
