Question about Samsung SyncMaster 753S 17" CRT Monitor
HOW TO REPAIR A NO POWER COMPUTER MONITOR - Samsung SyncMaster 753S 17" CRT Monitor
  • subir das Dec 19, 2008
    no power, but a knocking sound is going on.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The best approach would be to measure resistance and voltage readings at critical components referencing a schematic diagram or a service manual. Pls try here or here.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 12, 2008
Monitor light stays off. No power. On-off switch doesn't turn monitor on. Checked power cord and cord to computer. Both work with a substitute monitor.
You are infromign that checked VGA and power cables with a substitute monitor. Might be useful to chek your computer actually working with that substitute monitor.
Additionally, in most monitors, when turned on but not connected to the computer's video outlet, you get a message tinicating something like "NO SIGNAL", or in any vay, making you to know that your monitor is not connected.
If disconnected to computer but with power on you only get a black screen, you've got a defective monitor.
I'm not an electronic technician so can't suggest you what parts you should replace to rpair you monitor, so it you don't really have technical experience repairing monitors, you should take it to repair service.
Aug 12, 2015 | Computers & Internet
Dell stuck in power safe mode
A blinking power light is not indicating power safe mode, it indicates a failure of the power supply board in the monitor. Here is a link to repair guides that show how to open and repair the power supply boards in the Dell E173 series of monitors;
http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
I hope this helps,
Apr 08, 2012 | Dell E173FP 17" LCD Monitor
Lcd-17v8 monitor power won't stay on. westinghouse monitor
If the monitor turns on and goes directly to sleep, or it powers on briefly and shows an image then goes black then the monitor is defective. The first is often an I/O panel issue inside of the monitor. The second is typically a lamp failure within the monitor.
A simple test would be to plug a different monitor into your computer or this monitor into another computer. If the monitor doesn't work on another computer or a different monitor works on the same computer then the monitor is the issue.
If the different monitor does not work on the same computer or this monitor does work on a different computer then something on the computer is to be suspected such as a driver issue or a faulty video card.
If you find the monitor is defective then you should dispose of it (assuming it is not under warranty) at a nearby recycling center and purchase a new monitor. I would suggest something by Acer, Samsung, Dell, HP, NEC, or Viewsonic. These brands cost a bit more, but have much better track records.
Sep 06, 2011 | Gateway FPD2275W LCD Monitor
No power for IBM monitor model 6332-4CE
Your monitor power section has been faulty. so pls repaired it from service center.
Mar 24, 2010 | IBM E74 17" CRT Monitor
Lp2207 monitor is making a hissing sound
Your monitor is repairable, we have a repair service that can repair the power supply board in your monitor for $30 plus shipping. Let us know if you are interesrted in the repair at tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Jan 10, 2010 | Computers & Internet
LG Monitor L196WTQ when computer shuts or turns off
You have a power supply in the monitor that is about to fail. Check out his article on our web site about repairing this model - www.ccl-la.com If you can solder then you should be able to do the repair yourself. It involves replacing 6 small parts. If you don't want to do the repair yourself we do offer a repair service for $30 plus shipping. Let us know if you have any questions about the repair or the repair guide.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | LG L196WTQ Monitor
Light flashing
Try another monitor on your computer to make sure that your computer is booting up properly.
If your running into the same problem with a known good working monitor then the computer is the problem.
If the known working monitor turns on then you know the original monitor is bad.
Sep 03, 2009 | Gateway FPD1975W 19" LCD Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jul 19, 2009 | HP Pavilion F1703 17" LCD Monitor
ViewSonic Va 912B no power light, no display
Your power suplly is blown you can repair if you know alittle about repair can use a soldoring iron. You have to take the back apart and look at power supply. Look for blown caps they show raised tops bubbling on top. If you can't repair I do repair of monitor for the schools where I live if you don't want to try and repair it cantact me I will pay for shipping for parts. stabelable@q.com
Good Luck.
Mar 16, 2009 | ViewSonic VX910 19" LCD Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
137 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
