Question about Tally 6312 Matrix Printer
Platten cal cable
When i go to start printer t6312 latten cal cable "error is coming ...
    Problem Solver:
  • 15 Answers
Replaced controller board can solved this problem.
Posted on Jan 08, 2013
    Problem Solver:
  • 5 Answers
Do platen calibration then also same problem change platen sensor
Posted on Feb 23, 2010
Printer platen rubber is hardened
you need some rubber rejovinator. This will remove the ink from the platten and "soften" the rubber platten
Feb 24, 2013 | AMT Datasouth ACCEL-6350 Matrix Printer
What does canon pixma mp830 error code 6000 mean?
That is a line feed error (6000) It also should be flashing 3 times for this error on the on/off button.
This could be
1. Timing sensor unit QM2-2683
2. Timing **** disk film QC1-6229
3. Feed roller ***'y QL2-0925
4. Platten unit QM2-2923
5. Logic board ***'y QM2-3078
6. Paper feed motor QK1-1502
Mar 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Errore cal insuf
__________________________________________ Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 09, 2011 | Samsung CLX-2160N All-In-One Printer
My printer Lipi 2280+ printing properly with 15*12 and fanfold 8.5*12 paper,but when i am using paper width slighly smaller than it less than 8.5 width printer gives paper with error>kindly suggest
You see the "Paper Width Error" on the 2280+ because the print job being recived by the pritner is wider than the physical paper which will cause the pritner to print on the platten, in order to rectify the problem.
  1. Ensure the print job on the system is less than 8.5 inches wider
  2. Perhaps move the paper in the tractors to the right
  3. Disabling the Paper Width Sensor will clear the error but may cause the printer to print on the Platten which may reduce print head life, the Paper Width Sensor can be disabled in the following way;
    Start with the printer Powered OFF
    Hold Down the ONLINE button and power the printer ON keep ONLINE held down until you see ASCII80 ASCII136 on the top line of the display
    Press the button under NEXT repeatedly until you see APW on the top line of the display
    Press the button under APW
    Set APW = OFF
    This will disable the APW sensor and you will not see the Paper Width Error
Dec 08, 2010 | TallyGenicom 2280 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
My printer shows an error of platen cal cable.How can I solve the problem
Hi
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Hope it can resolved issue Thanks you for using Fixya
Mar 22, 2010 | Tally 6312 Matrix Printer
Shuttle error on a t6312
it may be problem with encoder strip or shuttle sensor
Jan 21, 2010 | Tally 6312 Matrix Printer
Describe your Tally Matrix T2280 Prion power up
Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
· Start with the printer powered OFF and at normal room temperature
· Hold down the ONLINE and SETUP button and power the printer back on
· Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
· Press the button under ‘TEMP CAL’ (button 3)
· Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
· Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
Jul 09, 2009 | Tally Matrix T2280 Printer
THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Apr 09, 2008 | Tally Matrix T2280 Printer
Error Message appear when printin
It is almost two years i started using this printer but recently whenever i;m printing with this printer, i get a report; " Cam Platten Error" and my document fails to print. Please help me.
Mar 15, 2008 | Hi-Touch Imaging Technologies HiTi 730PS...
Tally 6312 Matrix Printer Logo
247 people viewed this question
Top Tally Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
