Question about HP LaserJet 1160 Printer
THe orange light on the printer continues to blink after...
Download drifer HP LaserJet 1160
Posted on Mar 19, 2009
cene765
  • 787 Answers
SOURCE: ORANGE LIGHT BLINKS TWICE
2 blinking means "No Paper"or "No Paper in tray"
Posted on Oct 07, 2009
Testimonial: "Thanks for the helping hand! Even tho my printer has paper, I think it was not recognising it."
IB4G2008
  • 3587 Answers
SOURCE: The light blinks 12 times, and nothing will print
suggest you need a new set of printer drivers
remove old version first
go here for new ones
re install
Posted on May 03, 2008
SOURCE: hp 1160 light blinking
orange & green light on
Posted on Dec 23, 2008
pineworks
  • 4041 Answers
SOURCE: When I turn on my Canon iP3000 printer the power
Hello try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Dicedonions
  • 118 Answers
SOURCE: orange ink light blinks. printer will not print.
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome trouble shooting site
hope this helps and good luck
Posted on Apr 29, 2010
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
May 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
There is a blinking orange light on my printer but I replaced the toner not too long ago.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Apr 20, 2011 | Lexmark E260dn Laser Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
Jul 11, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Hp 1160 light blinking
Nov 11, 2008 | HP LaserJet 1160 Printer
re install
Mar 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
HP LaserJet 1160 Printer Logo
938 people viewed this question
Ben Johnson
