Question about Asrock 775i65G Motherboard
My Microphone is not working
Hello Jastababe,
My microphone is not working for Windows XP prof, but i can able to listen sound but i cant able to speak out , i checked control panel in Recording option Microphone button is disabled .
I am using asrocks 775i65G motherboard and Cmedia 9761A 5.1 channel audio CODEC for audio . Plz help me out from this problem.
Thanks,
  • adrianpragac Apr 16, 2009
    My motherboard can play sounds but when i plug a microphone, nothing happens, i cannot hear my voice.,,
  • 3,267 Answers
Simply enable the microphone and check the audio control tab to see if the microphone is not mute....sodeep
Posted on Mar 19, 2009
Audio driver is working properly but mic is not working.....using lenovo g430 3000
If the audio driver is working properly but the microphone isn't, ensure that: 1(a). The microphone is not muted.On Windows XP, go to start, run and type sndvol32 and press enter button to launch the Windows Sound Volume Management Panel. Under the Microphone volume control, uncheck "mute" box.This should make your microphone functional again. (b). The wrong microphone may be selected, esp. if your sound-card has an external port for microphones.To rectify the problem, use 1(a) as illustrated above, go to File>Advanced Controls and select Input Devices.Under the Microphone advanced settings, you'll see MIC1 Select and MIC2 Select. Switch the selection as appropriate until it works. 2. If the audio driver has it's own Sound management Panel, e.g that of Realtek, open it's sound control panel and disable all microphone effects that may be enabled. 3. Ensure that sound acceleration is maximum. Open the DirectX Diagnostics Engine by going to Start>Run> and type dxdiag and press enter button.When the window opens, click the Sound tab and slide the Sound acceleration bar to maximum.
I hope my solutions work.Have a good day.
Feb 11, 2011 | Lenovo IdeaPad Y430-3231U Notebook
I just bought a new gigaware earclip monoheadset with mic. the problum is i cant seem to get the mic working the sound works great but i just cant get that voice to work
Hello Mithmar hi, try setting the volume for your microphone, (i'm assuming you are using X P) to do this right click the speaker icon (or the mixer icon) on the lower right side of your screen, you will go to the volume controls section, goto options, then properties, select recording. check the microphone, then click apply/ok. On the mixer there is now the microphone slider. Test your microphone by loading the sound recorder program (start, all programs, accessories, entertainment, sound recorder, press the red button) then shout to the microphone, you should see wave patterns on the recorder, your microphone is working fine. at this point let me know your progress.
Oct 09, 2010 | Audio Players & Recorders
I downgraded to windows XP 2002, now I can,t use
Hello there!
That could be only problem with your sound device drivers. Do your speakers work?
If they arent also working then I'm probably right, try and reinstall your sound drivers on your new machine again, if thats not working, try to download them from internet, and you should have your problem fixed.
And one more thing, if we are thinking about the same microphone (the one integrated to your laptop computer) then you should be fixing your problem with steps i told you. Good luck!
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Microsoft Windows XP Professional With...
Hello, i cant hear the microphone over the speaker
Make sure your microphone is not muted in the control panel, under sounds.
Nov 20, 2009 | Gateway Computers & Internet
My second Computer windows Xp Prof. problem with "MICROPHONE".
go into your Control Panel, find and double click on Sounds and Devices- click on the Voice tab, under Voice recording - change the Default device: to the device you are using. this is not a monther board problem, its software problem, as long as you are sure that the mic is working
Aug 14, 2009 | Microsoft Windows XP Professional SP2 Full...
Internal microphone is not working under Win XP
I don't think the laptop comes with a microphone.
Apr 21, 2009 | Dell Studio XPS 16 Notebook
Dell inspiron 6400 Soundcard Microphone
sorry for the delay in responding:
for Vista system ... use the following picks:
Start ....Control Panel,...... Hardware and Sound, .... Manage audio devices....Recording......Line in ...try the advanced features to control the computers auto adjustment etc.
Hope this helps
Apr 05, 2009 | Dell Inspiron 6400 Notebook
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
I have got Windows Vista Home premium removed, and installed Windows XP professional. Since then, my microphone has stopped working, eventhough integrated webcam is working fine. While I try to listen...
If your microphone has stopped working check to see if it is plugged in. If the drivers are installed correctly, and confirm that the diaphragm in the microphone has not blown.
If you need more help tell me
RCF
Aug 30, 2008 | Computers & Internet
Microphone problem
Hello there,
Have you checked all arround the Sound and Audio Controllers?
Do you have audio?
Jun 02, 2008 | Compaq Presario 700 470024-192 Notebook
Asrock 775i65G Motherboard Logo
339 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
