Question about Braun Shavers Male Pulsonic System 9595CC with LCD Screen Electric Shaver
9595 pulsonic Trimmer not staying in closed position, permanently open.
  • aegreenie Feb 11, 2009
    Not only won't my trimmer close all the way, but it won't even turn on.
  • Anonymous Mar 14, 2009
    Trimmer won't stay open, and trimmer blade dose not project to a cutting position.
2 Suggested Answers
  • 4 Answers
SOURCE: Braun Pulsonic model 9595. Trimmer will not close
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Posted on Aug 16, 2010
Side burn trimmer won't stay closed on 790cc braun razor .
Almost certainly, the trimmer is broken and will need replaced. The part and replacement video instructions can be fount at shaveroutlet.com
Braun Pulsonic and Series 7 Shaver Trimmer Assembly
Jan 22, 2017 | Braun Health & Beauty
Dome light and courtesy light stays on in my 1987 S-15 GMC Jimmy even when car is off and doors are closed
courtesy lights have a 3 position switch 1 is for doors open --on /off 2 is for light off permanent and 3 is for light on in car permanent for reading etc. Other than that check the door switches for a permanent earth fault.
Apr 23, 2013 | 1997 GMC Yukon
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
Trimmer on Braun Pulsonic shaver won't stay shut?
The trimmer is broken. This is a common problem with this model and only an authorized Braun repair center can help you with this. There is one in Evanston, IL that can accept shavers from all over the US. Their phone number is 847-869-7755
Aug 19, 2010 | Braun Pulsonic Rechargeable Cordless Men's...
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
Mar 29, 2010 | Braun Health & Beauty
The beard trimmer on my Braun 9595 won't close all the way. Operates normally otherwise.
The trimmer is broken. This is a common problem with your model shaver. The part you need is not available to the consumer and you would not likely be able to install it if you could buy it yourself. You will need to contact a Braun Service Center for repair. If your shaver is less than two years old, it should still be covered under warranty.
For Braun Authorized Service Center call 847-869-7755
Mar 28, 2010 | Health & Beauty
Ms3 2700 trimmer will not lock in closed position.
This is a common problem with this type unit. Most likely, the mechanism that locks the trimmer in the down position is broken. It can't be effectively fixed but you can permanantly put it in the down position by super gluing it down. This will allow you to use the shaver to shave but you will no longer be able to use the trimmer.
Another remedy would be to purchase the replacement lower unit found on shaveroutlet.com. See link below
http://shaveroutlet.com/remington-ms32700-lower-unit-p-210.html
Jan 21, 2010 | Remington Health & Beauty
Trimmer not retracting back into shaver all the way
Hi Sorry I don't have the answer but this must be a common problem as my braun has the trimmer sticking out at 45 degrees when closed. The head lock went 2 weeks before the trimmer wouldn't retract so it looks like a design problem
Jun 15, 2009 | Braun Pulsonic Rechargeable Cordless Men's...
The pop-up long hair trimmer on my pulsonic razor 9585 will not stay closed
seems like the hinges have gone loose. do you notice an broken laches?
Sep 23, 2008 | Computers & Internet
Braun Shavers Male Pulsonic System 9595CC with LCD Screen Electric Shaver Logo
85 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
