I need a jack n' poy program in java using while loop or for loop or do while or if else if..please help me i need it now!
    Scholar:
  • 134 Answers
Try this link
http://www.hotscripts.com/Detailed/19632.html
I hope it helps!!!
Posted on Dec 12, 2008
2 Suggested Answers
SOURCE: jack n' poy program in java using loops
java code of jack and poy
Posted on Sep 14, 2009
Java program jack poy
restore using control panel use the utility system restore and put the last days that you know the sound was working Good.
God bless you
Jul 20, 2013 | Ultimate Sound COMPUTER ABS | Ultimate V1...
Write a programe that display the factorial of a no using while loop with output & explaination
I can show you in both Java and Python. Since you said you want a while loop I will skip how to use a for loop. Since you did not specify, I will assume you are not taking input from a user but simply typing it into your code. I have written the codes, commented them and uploaded them to pastebin.
In Java
In Python
Hope this helps!
May 01, 2012 | Borland JBuilder X Enterprise...
How to use goto un java?
GoTo statement are not available in Java Rep)
1) Goto statement decrease readability of a program.
2) Goto statement may from Infinite loop
3) Goto's are not part of Structured programming
4) Goto statments make documentation difficult.
A goto statement can cause program control to end upalmost anywhere in the program,for reasons that are often hard to unravel ,However almost always, there is a more elegant way of writing the same program using if,for,while and switch. These constructs are far morelogical and easy to understand.
This is seldom a legitimate reason for using got, and its use is one of the reasons that programs become unreliable, unreadable.
goto is a keyword in java which you cant use in code.i guess if you use goto, you will get compiler error
Jul 30, 2011 | Sun Computers & Internet
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
public static void main(String[] args)
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
Feb 24, 2011 | Sun Java Programming Language (cdj-275)
Is java perfect for projects or I must use VB.Net !please help me
yes java is perfect ...you need not any other language if you have full command on java. okay for more info about programming just mail me at niranjan27423green@gmail.com
Aug 19, 2010 | Microsoft Windows XP Professional
The loop and the manual tone store functionality !
Usually the loop in is used with an EXTERNAL effects module where the audio signal is "looped" out through the external effect module and then back to the power amp to drive the speaker in the cabinet. The LOOP IN jack would receive signal from the EFFECTS module OUT jack.
The source to go TO the effects module INPUT may come from a jack such as preamp out, or sometimes the same loop jack if it usess the TRS (Tip-Ring-Sleeve) connection method.
If you do not have an external effects module, all this is a moot point in your case.
Jul 17, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
How to convert infix to postfix using stacks in java programming?
u can try the follwing coding
import java.io.*;
import java.util.*;
//begin coding for the stack interface
interface Stack<E>
public boolean isEmpty();//tests is current stack is empty. Returns true if so, and false if not.
public E top() throws StackException;//retrieves value at the top of the stack. Stack cannot be empty.
public void push(E value) throws StackException;//pushes a value on the top of the stack.
public void pop() throws StackException;//removes a value from the top of the stack. Stack cannot be empty.
}//terminates coding of Stack interface
//begin coding for the objArrayStack class
class objArrayStack<E> implements Stack<E>
//constructor
public objArrayStack()
topValue=-1;
}//terminates constructor
public void push(E value)throws StackException
if(topValue<ArraySize-1)//currrent stack is not full
++topValue;
Info[topValue]=value;
}//terminates if
else //current stack is full
throw new StackException("Error: Overflow");
}//terminates push method
if(!isEmpty())//current stack is not empty
--topValue;
else //stack is empty
throw new StackException("Error: Underflow");
}//terminates pop method
return topValue==-1;
}//terminates isEmpty method
if(!isEmpty())//stack is not empty
return (E)Info[topValue];
}//terminates top method
//declare instance variables
final int ArraySize=10;
private Object Info[]=new Object[ArraySize];
private int topValue;
//begins coding for the StackException class
class StackException extends RuntimeException
//constructor
public StackException(String str)
super(str);
}//terminates text of constructor
}//terminates text of StackException class
//method to convert from infix to postfix notation
public static String InToPost(String infixString)
//operator stack initialized
objArrayStack<Character> operatorStack = new objArrayStack<Character>();
//postfix string initialized as empty
String postfixString = " ";
//scan infix string and take appropriate action
for(int index = 0; index < infixString.length(); ++index)
char chValue = infixString.charAt(index);
if(chValue == '(')
operatorStack.push('(');
else if(chValue == ')')
Character oper = operatorStack.top();
while(!(oper.equals('(')) && !(operatorStack.isEmpty()))
postfixString += oper.charValue();
operatorStack.pop();
}//end while loop
}//end else if
else if(chValue == '+' || chValue == '-')
if(operatorStack.isEmpty()) //operatorStack is empty
operatorStack.push(chValue);
else //current operatorStack is not empty
while(!(operatorStack.isEmpty() || oper.equals(new Character('(')) || oper.equals(new Character(')'))))
}//ends while loop
}//end else
}//end else if
else if(chValue == '*' || chValue == '/')
else
while(!oper.equals(new Character('+')) && !oper.equals(new Character('-')) && !operatorStack.isEmpty())
}//end while loop
}//end else
}//end else if
else
postfixString += chValue;
}//end for loop
while(!operatorStack.isEmpty())
if(!oper.equals(new Character('(')))
}//end if
}//end while
return postfixString ;
}//terminates text of InToPost method
public static void main(String[]args)
objArrayStack mystack = new objArrayStack();
System.out.println("Enter a string");
Scanner scan = new Scanner(System.in);
scan.nextLine();
String str = scan.nextLine();
InToPost(str);
}//terminates text of main method
}//terminates text of objArrayStack class
Mar 16, 2010 | Sun Java Programming Language (cdj-275)
Java won't load on my computer
id suggest that you uninstall java and delete the folder from the hard drive after you uninstall it from the computer, and then clean the registry of any instances of old keys associated to java,then redownload and reinstall java fresh,be sure its the right version for your Vista ( home,Bussniess) Hope this Helps Steve
Oct 01, 2009 | Computers & Internet
Java programming
I ll give you some reference book names for core java they are the best,
1)Head First Java by Kathy Sierra & Bert Bates
2)SCJP 5.0 by Kathy Sierra & Bert Bates
the first one is the best for the beginners read it before you go for any other
good luck
Aug 14, 2008 | Sun Java Programming Language (cdj-275)
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
