Question about Toshiba 50HM66 52" Television
Wont turn on
I have a toshiba 50hm66 tv
i try to turn it on and the blue led light will come on then the yellow light will blink 15 times , and no picture or sound ,
it will repeat itself alone .
help ?
  • 1 more comment
  • floresboy1 Dec 12, 2008
    thank you for comment so fast ,
    but i dont think its a convergence problem ?
    i recently replaced the back light bulb !
    and now that wont even turn on !
    the picture was fine before !!
    i pulled out the light bulb from back and it looks good !
    put it back on and same thing it tries to come on but wont !
    help meeeeeeeeeeee.....please. ,
  • jffryhurst Jan 11, 2009
    TV won't turn back on with a picture. Sound is good. It won't turn on the lamp, which is new.
  • Anonymous Mar 19, 2014
    still have sound but no picture
  • Toshiba Master
  • 5,138 Answers
Replace both of your STK ics 392-560s or 570s they maybe 392-110s if so use 392-180s call electronixs for parts 1-800-223-3205
Posted on Dec 12, 2008
  • ladywinn
    ladywinn Dec 12, 2008
    These are the convergence chips STKs 2 of them.
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
50hm66
Some possible reasons include: New lamp is generic and or has a issue----excessive dust or dirt inside the unit on fans etc.
Some of these units had a feature in the menu for quick on where lamp is lit at low level all the time---this shortens the life of the lamp etc
If you did not have this issue before lamp replaced I would suspect a generic cheap bulb may have been used instead of the Toshiba cartridge / lamp combo which costs more.
With the quick on if the set has it normal time is 20 seconds for screen to light----set WILL DETECT IF LAMP IS NOT COMING UP FAST ENOUGH OR BRIGHT ENOUGH.
Generic lamps (cheap) will never be as bright or last a long as a OEM lamp unit.
Just some thoughts based on your question.
Aug 28, 2012 | Toshiba 50HM66 52" Television
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Thanks.
Sep 18, 2010 | Toshiba 50HM66 52" Television
I just replaced the lamp in my tv, it will work fine for 10-15 minutes, after that the picture will start to flicker and then just go out completley and th lamp light will blink on the tv set, what could...
My 50HM66 did the same thing. Try putting a fan to the side of the tv so it blows cool air around the back. I also removed lamp and vaccuumed as best I could. I think this is an overheating issue with the tv.
Sep 03, 2010 | Toshiba 50HM66 52" Television
I have the 50hm66 tv, replaced the main power supply board, and then the aux. power suppy board, still no lamp (lamp is good), 15 yellow blinks What you think ???
U hear alot of clickings,few mins tv is on?The board call the Ballast board is dead.This Ballast board help to ignite the projection lamp.
Aug 13, 2010 | Toshiba 50HM66 52" Television
Replaced lamp on my toshiba 50hm66 and still wont turn on
hello i'm not sure if i'm right but when you install these lamps you rght have reset the lamp counter
shaun
Mar 21, 2009 | Toshiba 50HM66 52" Television
Toshiba DLP 50HM66
This is a feature of the Hot Restart feature
Jun 18, 2008 | Toshiba 50HM66 52" Television
Solid yelow led and the red led is flashing
Check your manual or:
http://www.toshiba.ca/web/pdf/5056HM66_EN.p.pdf
Use the quick restart procedure
Jun 13, 2008 | Toshiba 50HM66 52" Television
Toshiba 50HM66 52" Television Logo
327 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
