Question about Motorola Mobility RAZR V3
My phones speaker volume won't go up. It just stays on the lowest setting/
This morning I woke up to find that my phone, when I'm on a call, is stuck in the lowest volume setting. I try and push the side button to turn up the volume and the little screen pops up with the volume adjuster on it, but it won't budge from the lowest volume setting. It's making it very diffcult to hear anyone! I've already updated the phones software. I've tried turning it off and on many times and nothing is helping. Does anyone have any ideas?
  • 22 Answers
Open the set and clean the volume buttons.Any leakage or shoting in keys especilly volume keys creative this types of problems
Posted on Mar 14, 2007
SOURCE:
My lg optimus f3 phone has no sound only when i
The problem is probably due to the speaker volume is set to its lowest but the headset volume is set to high. Try to play music or a video without plugging a headset and ram up the volume up button to the max. Hope this helps
Oct 16, 2014 | Cell Phones
Orange light mean
The orange light indicates its stuck in charging mode.
Hold volume down and power for 15 seconds, you should see the bottom buttons flash a few times and it will go into recovery mode.
Use volume keys to highlight restart phone and press power once.
Oct 12, 2013 | HTC Cell Phones
Even after turning the volume down to the lowest setting, it is too loud. How do I turn the ringer off completely and just use the flashing red light to indicate an incoming call?
Hi, sometimes the buttons get stuck, try hitting the volume key + a few times whilst changing the volume. have a look at the posted video, it is off http://www.abbeytelecom.com where there are loads of how-to videos realating to Samsung phone systems
Jul 11, 2011 | Samsung DCS 12 Corded Phone
My phone is not working the handset now in order to hear you need to switch to speaker
When this happens to your phone this usually is as a result of the speaker being faulty or the volume has been reduced to the lowest level. Try increasing the volume first and if that does not work then the speaker is bad and needs to be replaced or fixed.
Hope this solution has been helpful?
Mar 10, 2011 | Motorola Mobility RAZR V3
LG GC900 stuck on silent
Hi
Since you have done all the necessary checks and the phone still stays on silent, then the problem is from the speaker which is where ring tones come out from when you receive a call or text message
The solution is to have the speaker replaced because it is no longer working. A repairer can help you replace it if you cant do it yourself.
Cheers
Mar 11, 2010 | LG VX3100
Now sound from speaker
your mobile's sound ic is damaged or burnt u need to change it...
Dont forget to rate
Sep 07, 2009 | Cell Phones
Phone doesn't turn on.
You should not allow the battery to fully drain,it will die sooner.
Remove the battery for 5mins, replace,and then try and turn on the phone.
Apr 07, 2009 | Motorola Mobility RAZR V3
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Can't hear anything
fuck same help shoud i disassemble it
Jan 18, 2008 | Sony Ericsson W300 Cellular Phone
The buttons...well..they don't work.
If you slept on it you might of got the keys stuck. so find one of the solved problems to open up your keypad and check if theor stuck or if the cabel is loose.
Mar 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
277 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
