Question about Lands Phones
My nokia flip top phone can't remember type has started to vibrate when i answer a call. The vibrating is quite loud and lasts for a long time.
My cellphone 6101 cannot send without loadwhat will i do????
Posted on Feb 07, 2009
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
Nokia c5 is doing only vibrating.
you will need to set your volume to a higher level in order to hear it try changing your profile to either normal or loud, if you have done this and it still only vibrating there will be a fault with your speaker and will need to be fixed or replaced.
Aug 18, 2012 | Nokia C5 Cell Phone
Today my Nokia 1209 stopped vibrating. Instead of vibrating it will do a squekling sound.
My dear, maybe you or some one else mistakingly changed the profile. All you have to do is, select the menu button on your phone, select SETTINGS, select PROFILES, select GENERAL OR LOUD, select OPTIONS AND PERSONALIZE, then select style to VIBRATION,RINGTONE, VOLUME and every other thing you wish to adjust. AFTER WICH, select ACTIVATE PROFILE. hope that works
Jul 21, 2011 | Nokia 1209 Cell Phone
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
Loud vibration
If it is a frost free check the fan inside. The fans can have bearing failure after a few years thus causing the vibration. Also the compressor underneath is mounted on rubber vibration dampers and if one of these rubber mounts fail then the compressor will start vibrating against the refrigerator frame causing a loud vibration. If none of these apply gently press on the side and front panel of the refrigerator to try and locate the source of the vibration as any where metal is vibrating against metal the side and front panel act as a sounding board amplifying the sound. If you cant locate the vibration then you may have a more serious problem and may need to call a technician.
Oct 09, 2009 | Roper Refrigerators
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Turn vibrate on ?
let me sole it by steps do it step wise
press
1. menu 2. profiles 3. general 4. personalize
then move down to incoming call alert than select off
and move vibration select on
did i solve the problem
Jun 14, 2008 | Cell Phones
My cell phone always vibrates
u edit ur profile and disable vibration first it wil automatically change ....
eg: u selecting meeting profile means u can edit that profile and turn off the vibration
May 20, 2008 | Nokia 6288 Cellular Phone
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
In vibrate mode, phone continues to vibrate after being answered
The phone is in "vibe then ring" mode.
Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
Oct 30, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
561 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
