Question about Toshiba 53H71 53 in. Rear Projection Television
Samsung SP42W4HPX I Have a Samsung rear projection tv,Picture is all outlined in green. we had a technician out and he advise that the power Convergence board needs replacing and this item is no longer available.Can anyone advise where i can get this item or fix it as the tv is only 3 years old and i dont want to dump it. Kind Regards,
J'ai vercé le liquide qui se trouver dans la lampe bleu
Posted on Aug 26, 2008
The LED is on on the front of the tv but when I turn it on or off with the remote or the main button on the front of the tv the light goes off and nothing happens
Posted on Apr 02, 2007
    President:
  • 3,130 Answers
The Model number is wrong foir the make, unless this TV is not a US model number. Please double check the model and get back to us.
Posted on Mar 21, 2007
  • 67 Answers
Convergence boards for a tv are kind of hard to come by after 3 years old where did u buy the tv? if from sears you can goto the site and look up the parts or contact the manufactuar directly on there site for a parts section. www.samsungparts.com i tried to look up your model number said it was invalid try that and good luck also convergence boards have a dcu on the board looks like a small motherboard and u might have to take the old one off and put it on the new one with solder GL hope it helps
SOURCE:
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung SP42W4HPX, black semi circle bottom of screen & 3D effect
sir/mam the problem of your t.v is weak picture tube,i have encountered for that kind of problem already.
Jul 31, 2009 | Televison & Video
Samsung Tantus 119cm 100Hz Rear Projection Problem
i have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Oct 14, 2008 | Zenith E44W46LCD 44" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
SAMSUNG SP47W3HF1X
hi i dont suppose you have floor standing speakers next to it
as mine done that moved away speakers now all is fine
Nov 17, 2007 | Samsung HCM553W 55" Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Samsung SP42W4HPX
The convergence wouldn't cause it to go all green. Green outlines yes but, not all green. Get a technician to look at it.
Mar 06, 2007 | Toshiba 53H71 53 in. Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung rear projection sp42w4hpx/xeu
Try plugging the power cable out for the night. If it doesn't solve it there's probably a problem with the power supply that needs professional care. Good luck
Jun 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
326 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
