Question about Dell 3100cn Laser Printer
Vertical toner smear-off in all colours
When I print, the pictures and/or text on the bottom half of the paper gets smeared off in 10-12 vertical points, about one inch long. It's as if the feeder can't get a decent grip and spins on the on the paper before the toner gets burned onto the paper.
The smearing goes all the way through the colour so you can actually see the white paper colour on those points.
I have printed solid CMYK pages, and it has the problem on all pages.
What to do?
  • 2 more comments
  • stormclouds Dec 12, 2008
    For me, the color appears to "smear" across seven vertical lines spaced equally apart (about 3/4 inch) from the top of the page to the bottom. Toward the bottom of each page, between the seven lines, the color appears to spread in a fingerprint-like fashion.
  • Steve Minor Dec 17, 2008
    When I print the 20% coverage tests (Cyan, Magenta, Yellow) you can barely see anything, but on normal color print outs I get perhaps 5-8 small (1/4" long) vertical smears around 3/4 of way down the page--they are seperated by around 3/4" of an inch.
    Does not do this with B&W printing, only color.
  • johntgb Jan 03, 2009
    Same problem.
    When printing photos, top half of sheet is usually OK but bottom half has vertical smears as if there was an obstruction on the fuser or transfer rollers.
    Any ideas?
  • ryanetics Jan 15, 2009
    same problem here. mine happens in the middle of the page but yes, equally spaced spots where the ink just wipes off showing the white of the paper. This is incredibly frustrating!
Yes, I had just found that! Alas, sanding helped, but I finally just said screw it and kept the cover off the drum alltogether and it solved the problem.
I'm at 8,000 pages so based on some of the netagive reviews I would guess my drum is within 2-3k pages of dieing anyway.
Posted on Feb 03, 2009
Looks like the ridges inside the cartridge are catching. Here's a solution;
http://www.ahfx.net/weblog.php?article=133
Posted on Feb 02, 2009
Print problem sir in 2420L
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing.
Happy with us Dial Epson Printer tech support phone number 1-877-778-896 for technical support of customer executive regarding with the Epson printer, if your printer is not connected with your PC & Laptops, Don't worry, dial our Tollfree 1-877-778-8.9.6.9 and get better and feasible solution of your issues within a time in the USA.If you want more information regarding with Epson n printer visit us:http://printertechnicalhelp.com/epson-printer-technicalhelp.html
Nov 25, 2016 | Office Equipment & Supplies
Toner smears on all print outs. Looking for what part to replace.
Do you mean when the print comes out the toner smears on the paper when you touch it? If so, then it's the fuser that isn't working properly.
However, if you mean when the print comes out there is smeared toner in various places on your print, but the smears are fixed to the paper, then the cause is more complicated and could be caused by a number of different problems within the printer.
Mar 03, 2014 | Xerox FaxCentre F12 Laser Printer
I have samsung CLP610nd printer. and it's printing vertical blue smears on the paper. what is the problem and how to rectify it please
have you tried replace the (C) toner. it might be the toner drum issue. and if the rest of the color is working fine. then there is no major issue.
just replace the (C) toner will do.
May 11, 2010 | Samsung CLP-610ND + Demo Laser Printer
Samsung CLP 300 wont print black
you need to clean image unit
if you dont have any expertise dont do it
Dec 14, 2009 | Samsung CLP-315W Laser Color Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printer smears on cold print
The toner cartridge sounds like the problem to me. Did you refill it? Or have it done? It sounds like an incompatible brand......toner is very model specific, and not just 'any' will do, and it often doen't mix well with the remaining toner i the cartridge if it is not completely disassembled and cleaned out. Just curious
Mar 16, 2009 | Brother HL 5250DN Laser Printer
My copier smears the middle portion of printed documents.
Cleaning the roller (drum) may have made things worse. You will need a new toner cartridge. However you should try and get a replacement from your supplier if the cartridge is not too old
Jan 02, 2009 | Canon imageCLASS D661 Digital Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Dell 3100cn Laser Printer Logo
489 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
