Question about Dell P1500 Laser Printer
P1500 clutch assembly
I tried removing the clutch assembly thinking it was the solenoid coil but after applying voltage to it it worked normally. When I test the connector on the board where this gets its power from its only 0.8v dc thrughout the test page cycle, It should be 24vdc or lower but not .8. When I latch the clutch in manually with a screw driver It pulls the paper then jams. I got it to print a test page once while engaging the clutch lockout at different times but I cannot replicate. Just got lucky My question is what tells the clutch to engage or where can I trace the power loss for it. I do nothing with the clutch it never pulls the paper thru since the roller with the clutch will not spin. All the circuit boards have no apparent problems as far as burnt spots or solder joints. I see no paper position sensor where is it? Help Please
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 1,362 Answers
If your only getting .8v then you have a bad board, does'nt have to show burnt spots. Change the board.
Posted on Oct 19, 2007
Where is P0877 automatic transmission fluid sensor located on a 2007 GMC Acaidia
DTC P0877: Transmission Fluid Pressure (TFP) Switch 4 Circuit Low Voltage
The transmission fluid pressure (TFP) switch 4 is part of the control solenoid (w/body and TCM) valve assembly and is not serviced separately. The TCM supplies 12 volts to the TFP switch 4 on the TFP switch 4 signal circuit; the TFP switch 4 has an internal case ground. TFP switch 4 is normally closed, Low. When oil pressure is present at the TFP switch 4, the switch is open, high. The normally low clutch pressure control (PC) solenoid 4-5 controls the transmission fluid to the 1-2-3-4 clutch. The TCM monitors the normally closed TFP switch 4 signal circuit to determine the 1-2-3-4 clutch status.
P0877
The TCM detects that the TFP switch 4 signal voltage remains low, 0 volts when the 1-2-3-4 clutch is commanded ON for 5.5 seconds or greater.
Action Taken When the DTC Sets
• DTCs P0877 and P0878 are Type C DTCs.
• The TCM freezes transmission adaptive functions.
Circuit/System Testing
Ensure the TFT is near the temperature displayed in the Failure Records.
Start the engine and place the transmission range selector in D6.
Observe the TFP switch 4 parameter while commanding 4th gear and then commanding 5th gear with the scan tool. The TFP Switch 4 should transition from High in 4th gear to Low in 5th gear.
? If the TFP switch 4 parameter state does not change, perform the Control Solenoid Valve and Transmission Control Module Assembly Inspection .
? If no concerns are found, replace the control solenoid (w/body and TCM) valve assembly.
Component Testing
Perform the Control Solenoid Valve and Transmission Control Module Assembly Inspection .
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Control solenoid (w/body and TCM) valve assembly replacement - refer to Control Module References for replacement, setup, and programming.
Perform the Service Fast Learn Adapts
May 13, 2018 | GMC Acadia Cars & Trucks
?Had a new starter and new battery put on my 1999 Chevy Tahoe.. we by it starts sometimes and sometime it don't..what could the problem be
I'm assuming just by the fact you had a new battery and new starter that sometimes when you turn the key to the start position , nothing happens . Is your vehicle a automatic transmission ? When it doesn't start have checked for battery voltage at the starter solenoid S terminal ? Is there B+ voltage at pins 30 & 86 for the starter relay ? Pin 86 while cranking the engine or trying to crank the engine over . Pin 30 check with key on . Try moving gear selector to neutral . Videos on youtube for basic automotive electrical testing . How to voltage drop test starter motor circuit Find a wiring diagram at www.bbbind.com
Starting System Circuit Description
Voltage is applied at all times to the ignition switch from the IGN A fuse 6 through CKT 242 (RED). When the ignition switch is turned to the START position, voltage is applied to the CRANK fuse 8 through CKT 5 (YEL). From the CRANK fuse 8, voltage is either applied to the clutch pedal position switch (M/T) or the transmission range switch (A/T) through CKT 806 (PPL). When either the clutch is disengaged (M/T) or the transmission is in park or neutral (A/T), voltage is applied to the coil of the starter relay through CKT 1035 (PPL/WHT). Since the starter relay is permanently grounded at ground G105 through CKT 150 (BLK), the starter relay energizes.
Voltage is applied at all times to the starter relay contacts from IGN A fuse 6 through CKT 242 (RED). When the starter relay energizes, the starter relay contacts close, and voltage is applied to the starter motor solenoid. Since the starter motor solenoid is permanently case grounded, the starter motor solenoid will energize two coils. The pull-in winding coil energizes in order to pull the starter motor solenoid contacts closed. When the contacts close, a plunger on the contacts causes the pull-in winding coil circuit to open. The hold-in winding coil then holds the starter motor solenoid contacts closed. Voltage is then applied to the starter motor from the battery through CKT 1 (BLK) and the closed contacts of the starter motor solenoid. Since the starter motor is also permanently case grounded, the starter motor will run until the ignition switch is moved out of the START position. When this happens, a spring in the starter motor solenoid moves the starter motor solenoid contacts and the plunger back to the rest position.
Jan 07, 2017 | 1999 Chevrolet Tahoe
Where is the neutral safety switch located on the transmission and is there another switch that would keep the starter from engaging?
If it is an automatic it is part of the Range sensor switch on the transmission where the cable hooks up from the linkage.
May 12, 2016 | 1999 Chevrolet Chevrolet Camaro
Why does the starter stay engaged on my 99 Chevy suburban when I use the remote start
Check the batteries. If remote is the one that came with it. could be wore out.
Nov 21, 2014 | 1999 Chevrolet Suburban
1999 GMC Sonoma 2.2L will not start.
What is wrong????????? That would be a guess on anyones part here ! Testing the electrical circuits involved would be the proper way to diagnose this no start problem ! Using a volt meter an wiring diagram to check voltage at different point's in the starter circuit . voltage drop testing ! Plus knowing how the starter system works !
Starter Circuit Operation
Voltage is applied at all times to the ignition switch from the IGN A fuse through CKT 42 (RED). When the ignition switch is turned to the START position, voltage is applied to the CRANK fuse through CKT 5 (YEL). From the CRANK fuse , voltage is either applied to the clutch pedal position switch (M/T) or the park/neutral position switch (A/T) through CKT 806 (PPL). When either the clutch is disengaged (M/T) or the transmission is in park or neutral (A/T), voltage is applied to the coil of the starter relay through CKT 1035 (PPL/WHT). Since the starter relay is permanently grounded at ground G102 through CKT 150 (BLK), the starter relay energizes.
Voltage is applied at all times to the starter relay contacts from IGN A fuse through CKT 42 (RED). When the starter relay energizes, the starter relay contacts close, and voltage is applied to the starter motor solenoid. Since the starter motor solenoid is permanently case grounded, the starter motor solenoid will energize two coils. The pull-in winding coil energizes in order to pull the starter motor solenoid contacts closed. When the contacts close, a plunger on the contacts causes the pull-in winding coil circuit to open. The hold-in winding coil then holds the starter motor solenoid contacts closed. Voltage is then applied to the starter motor from the battery through CKT 1 (RED) and the closed contacts of the starter motor solenoid. Since the starter motor is also permanently case grounded, the starter motor will run until the ignition switch is moved out of the START position. When this happens, a spring in the starter motor solenoid moves the starter motor solenoid contacts and the plunger back to the rest position.
Starter Voltage Drop
Jun 23, 2017 | 1999 GMC Sonoma
Removing bell housing
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 10, 2012 | Daihatsu Rocky Cars & Trucks
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
Feb 02, 2012 | Homelite Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How do you remove the clutch so that the pull cord can be replaced
Dec 31, 2011 | Garden
Need to remove flywheel ryobi RLH1100 mark2
Nov 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
Dell P1500 Laser Printer Logo
142 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
