Question about Acer Aspire 7720 Notebook
Acer notebook 7720
Bought brand new and never boots up on first try, usually boots up on second try and will freeze up when in hibernation mode
  • shawnarae418 Jan 29, 2009
    I have the same problem only mine started after my computer went out of warranty (it's like they know). It will do the same thing when Vista puts it to sleep, so I've turned that off. For a while I was putting it into hibernation instead of turning it off at night, and that worked for about a week. Now no matter if it's hibernated, put to sleep or turn off. When you try to wake it up it requires a reboot. If it's off and you attempt to boot it, it won't boot. Rebooting it will get it to come back on.
    I've run check disk on it and all came back fine. Anyother tests I can try to figure out the problem?
    Scholar:
  • 135 Answers
If its brandnew, take it back, its under warranty !
Posted on Dec 12, 2008
  • Uwe Klopfer
    Uwe Klopfer Apr 12, 2010
    this is more than lielyl caused by the time it takes the hard disk to be ready and the rest of the hardware is alraedy ready. Sorry that sounds weird.
    OK it works as follows :
    All component in the pachine needs to boot up. The one that takes the longest is the hard drive.
    Now the motherboard/bios effectively runs with the bootup, and when it "asks" the hard drive to give data to start the operating system (windows) the drive isnt ready and the bios assumes there is nothing, thus a boot failure. When you restart the machine the drive is already ready and when the bios asks the hard drvie to load the operating system the drive is ready.
    To resolve it do the following :
    When the computer starts up there is an option to go into setup (normally F1, DEL, F9 or something (also look for BIOS option maybe)
    In there go through the menus and look for "disk delay" or "drive delay" and then set that to say 5 seconds. Save and exit settings. Now the rest of the computer will wait 5 more seconds to give the drive chance to be ready before asking the hard drive for info.
    Hope that helps.
    U
Hibernate issue
Boot the computer into Safe Mode and try changing the Power Options.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
May 16, 2012 | Acer Aspire 4720 Notebook
The keyboard & mouse seemed to have locked up my acer aspire 7720, can't get any futher select user screen?
you can use the usb keyboard...also try your computer in safe mode and check the status.
you can get into safe mode by pressing/tapping F8 at the time when computer starts.
if you presses the key at the right time you will be directed to the page which says Advance boot option...you can select safe mode with networking so that you can connect to internet
Aug 11, 2011 | Acer Aspire 7720-4428 Notebook PC
My video card won't work. i was playing a game and it died. had to boot into safe mode. updated the driver and still no good
Reboot into safe mode go to driver and select roll back driver. This should help if not try system restore.
Dec 28, 2009 | Acer Aspire 7720 Notebook
I bought today my acer and it shuts down after a while and restarts automatically right after
Laptops/notebooks are configured to go into sleep or hibernate modes after so many minutes of inactivity. The amount of time varies whether laptop is plugged in to AC power or running from battery. You can change the amount of time and how the power button behaves by changing your power managment settings in the control panel.
Oct 03, 2009 | Acer Aspire 7720 Notebook
When the machine is cold it wont boot up on first attempt. you have to switch off using power button. it does this for 3 or 4 times. on the odd occasion when it does work on the first or second attempt it...
Hi , this is a common problem with Acer notebooks ,they are buggers for shipping laptops without fully testing bios firmware.
I have had this on numerous customers computers , its a simple fix just visit Acer Support to download latest firmware.
Hope this helps
Dennis
Wise PC Callout
Feb 18, 2009 | Acer Aspire 7720 Notebook
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Jan 30, 2009 | Acer Aspire 7720 Notebook PC
Network and Hirbernate
well when the acer aspire goes into hibernation, you should press ctrl alt delete whicj takes you to login. i
Jan 28, 2008 | Acer Aspire 5100 Notebook
No boot, screen blank after hibernation
NTLDR is missing Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in.
Getting into Windows Safe Mode Users who may not be able to boot into normal mode or are not able to .... This is the most basic Safe Mode option and has no additional support.
Good Luck, Please dont for get to Vote/Thank You.
Dec 26, 2007 | Acer Aspire 5610-4648 Notebook
Cant get out of hibernation
does the laptop boot at all ? or just not logging to windows ?
if not logging to windows then unplug the laptop's battery the replug it and restart
if the problem remains,, try to boot in safe mode by pressing F8 continuously and then choose Safe Mode
if you success in booting in safe mode go to control panel and disable hibernate then try to reboot in normal mode
Dec 25, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 7720 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
