Question about Mitsubishi VS-50805 50" Rear Projection Television
Fix picuture i replaced my bulb good picture not bright enough
  • 76 Answers
Try to clean all reflection glass at the back of the projector
Posted on Dec 12, 2008
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
Aug 31, 2012 | Samsung HCL652W 65" Rear Projection...
My tv not bright enough
i have a mitsubishi i bought a bulb from this dealer and i enstalled it now i believe that the picture isn't bright enough or is it just me? could a bulb not be bright enough that it gives a draker picture
Nov 10, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Picture is not bright enough, very faint, and cloudy. Appears as if the bulb is not bright enough or something. It has not been replaced recently. Cleaned the filter, checked settings. Does the bulb...
The coolant inside each of the tubes need to be flushed cleaned and refilled.Over the years of the TV's use, the coolant gets cloudy from heat. usually this kind of service can range from $350-$650+ dollars. Its not an easy job... Call your local TV repair professional to find what they charge to refill coolant. You can CLICK HERE to find a TV repair professional in your area, just type in your zip. 'best wishes'...
'if this helps you please rate, its like a donation :-)
http://tvtechwork.webs.com/
Oct 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Oct 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
My picture brightness is uneven - there is a persistant bright field on my screen.
I have the exact same problem with my AE700. It a started about the same time, around 2500 hours for me. I lived with it untill I could afford a new bulb which arrived yesterday. The old bulb was still working at a 3603 hours when I installed the new one. But the new bulb didn't fix the problem for me either. I may try to take it apart this weekend and give it a good cleaning. Andy
Jan 07, 2007 | Panasonic PT-AE700U Multimedia Projector
Can't take picture!!
It will say in your manual where to call or send you camera for repair. If you dont have a manual theres one here . You can read or print it free simply by clicking on the model # at the top of your post and scroll down Good Luck
Apr 23, 2006 | Olympus Camedia C-360 / X-350 Digital...
Mitsubishi VS-50805 50" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
