Question about Princeton Digital VL1716 17" LCD Monitor
Please help me remove the Key Lock
Just going crazy here.....My 17" Princeton monitor has a "key Lock" message on that I can not remove or get into the menu to change any settings, i have tried to reach princeton to ask this but can not get a hold of the and they are no responding back to my email......please help me.
  • mtdrmtdr Oct 04, 2008
    I have the same problem 19" Monetor
Your EPROM needs to be reset. To accomplish this please
1) Power off the LCD
2) Unplug your VGA cable
3) Press the up arrow at the same time you power on the LCD monitor.
4) You will see a message "RESET EPROM" 5) Power off the unit
6) Plug in your VGA cable
7) Turn the power on.
Posted on Oct 10, 2008
  • ctsstc Nov 27, 2010
    Thank you! so glad this worked :D
    Just had to do the power on while holding the up arrow
    Idk how someone locked it but they did :p
    now I can dim my monitor at night
    Just wondering but how did they lock it?...
    Champion:
  • 217 Answers
Hold the menu button down long enough and it should unlock, if it unlocks and then immediately locks back up then you have a main board problem
Posted on Mar 17, 2007
My monitor(view sonic e70fb ) is osd lock, n how how can get unlock
Hi Mandalavijay,
To unlock your monitor you need to hold two keys simultaneously for about 5 seconds.
In this case for your model you need to press the 1 key and the down arrow key and a message will appear which reads ' OSD Unlock'
Hope this helps...:) Your feedback would be appreciated.
Aug 22, 2011 | ViewSonic E70f 17" CRT Monitor
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
Princeton VL1715 monitor's pwr button is "locked." Can't turn-off
I have resolved this situation on other brands by holding down one of the advustment buttons while holding the power button in. You will see a message about "unlocking button" and a sliding bar if you find the right buttons.
Monitor Mike
Jan 06, 2009 | Princeton Digital VL17151 17" Flat Panel...
Key Lock?
Try this! Copied right from the Princeton Graphics support pages. (bless their hearts....'course it wasn't "real" easy to find; it was posted for a different monitor for a different problem... but it seems to work for different monitors... Mine's an LCD19D ... and no, it wasn't posted for my monitor either.)
--dadswank
Dec 23, 2007 | Princeton Digital VL1719 (Black) 17" LCD...
Princeton CD770MCN 17 driver and or setup program
My only suggestion: responsibly recycle that 17-inch CRT, and buy a used 17-inch LCD; around here, the local "government surplus" store is selling 3-year-old 17-inch LCDs for $50, plus taxes.
If it was a "plug-and-play" monitor, then there was _NO_ need for any "drivers" at all, because the monitor would identify which combinations of horizontal/vertical pixels and refresh-rates that it would support.
Oct 27, 2007 | Princeton Digital Custom CD770MCN 17...
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Princeton Digital VL1716 17" LCD Monitor Logo
2,218 people viewed this question
Top Princeton Digital Computers & Internet Experts
Daniel Dollive
Daniel Dollive
Tom Chichester
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
