-   I have tried to download the disc whaich came with the camera but for some unknown reason it wont register as on my pc etc hence cant download pics, I tried on laptop also for microsoft net meeting it said wrong version of windows?
-   debra10
Jun 04, 2008
-   i keep taking pics keeps telling me no pics in camera and wont save.-   evelinda
May 15, 2008
-   i want to be able to compy music and vedios from my computer to the camera and play them in the camera. currently when i do that the camera tell me there is no file-   QUETIA
May 10, 2008
-   I have Windows Vista and I cannot recieve my videos, What can I do to Download my videos?-   tiiiguh
I've had a couple of Fujis using this media exhibiting the same problem. I traced it to either A. dirty contacts on the memory card,B. dirty contacts in the memory card holder or the worst of the lot C. badly bent or fractured fingers in the memory card holder.
For A, a light rubbing with a pencil eraser will clean the contacts on the card.
For B. cut out a piece of ordinary printer paper the same width but slightly longer than the memory card And push the card in and out a number of times with the paper against the fingers and covering the card's contacts. That should clean the fingers inside.
For C. Remove the motherboard which has the card holder connected to it and replace the whole thing. If you find this too expensive or too much hassle use answer B but leave the paper in the holder with the memory except put the paper on the opposite side to the contacts. This is usually enough to get you out of trouble in an emergency. I know, it's saved a few tears with my 700.
The photo is a motherboard from the Oly C700 and the black box on the left is the card holder.
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
1. Make sure media is inserted correctly (this isn't always obvious with SmartMedia, for instance). Make sure media hasn't been write-protected.
Nikon 18-70mm lens just began sticking or jamming at 35mm. If I jiggle it awhile I can get to 70mm...
(More)
Nikon 18-70mm lens just began sticking or jamming at 35mm. If I jiggle it awhile I can get to 70mm but it will not go to 18mm.
