Question about Samsung DLP HL-P5663W 56" TV
TV will not turn on.
When I press the power button the TV sounds like it is turning on and a picture comes on but then disappears after a couple of seconds. Then the power, timer and lamp light start to blink. Samsung said to check the lamp. I checked the lamp and it was fine. What else could it be?
  • Anonymous Jan 27, 2009
    i have the same problem. I push the power button and it turns on. I see a picture with pink and purple lines going across the top half of the screen and i hear no sound. So then i try change the channel, turn up the volume, try to check out the menu button and even try to turn it off. But nothing happens. After a few seconds the tv freezes and the screen goes black. It didn't turn off yet cause i could hear noise coming from the tv and i see a light in the back of the tv. Like about 2 or 3 minutes after i turn it on it just shuts down. Please Help its pretty close to Super Bowl Weekend.
    Problem Solver:
  • 12 Answers
This is usually caused by 1 of 2 things.
1: You have a lot of dust in the vents so the bulb gets too hot. You might see a flashing red temperature light on the front status button. Clean the vents to the light housing and see if that solves the problem. You might also want to physically disconnect the power from the TV for about 30 seconds to allow it to reset if it is just a random problem.
2: Your light is about to go out. If you have had the tv for a few years, it is possibly time to replace the light bulb. You can usually tell this because the light will be dimmer than normal and possibly all 3 indicator lights will be blinking on the status button on the front.
HTH
Posted on Feb 19, 2009
    Genius:
  • 1,074 Answers
Your micro chip is faulty check the voltage comming out of the 42nd leg it shuold be 13 volts dc if you are not getting that voltage replace the microchip.and the eeprom ic.good luck
Posted on Mar 19, 2007
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
RCA 27F524T Power comes on But no Picture
i want to know who wants to sell me their rca t.v?
Jan 21, 2009 | RCA 27F534T TV
Samsung DLP HL-P5663W 56" TV Logo
446 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
