KEEP FORGETTING TO PUT NUMBER LOCK ON WHEN SWITCHING COMP ON. ON MY TOWER COMP NUMBER LOCK WAS ON AT START UP
SOURCE: number lock locked
Look for a key in the bottom left corner of the keyboard that says "fn", and hold it down while pushing numlock key. It should toggle then. As a side note, all other items that look the same way the numlock key looks can be used with that same "fn" key.
SOURCE: where is the wireless switch on my asus k53e laptop
The switch on most laptops is on either side or at the front. Sometimes it will be a switch to slide, or it might be a button to press.
Some laptops may not have a switch at all. In this case there will normally be a set of key strokes that you will have to hit to toggle the wireless ON and OFF.
Usually you will have to Press and Hold the FN function key then hit the Key that controls the wireless (F1 thru F12). The correct F1 thru F12 key that toggles the wireless will normally have the wireless icon )))).
save ur data on to mem card and remove ur battery,,put it back. switch on the phone again.
