Question about Philips Magnavox 27MS343S 27" TV
Tv goes off after it warms up AND pic. goes SHORT and WIDE prior
I have a 36' phillips magnavox smartt series t.v. and it shuts off after it warms up AND the picture goes short and wide prior to shutting off, can anyone tell me why and how to fix it ? will it be a costly repair job? thank you
  • rubster Dec 12, 2008
    what does that mean ? thank you for your help.
  • 116 Answers
Im betting the vertical deflection is failing, a capacitor that is in the vertical deflection circuit may be dry and as it heats up shorts shutting the tv off.
Posted on Dec 12, 2008
  • Justin Washburn Dec 12, 2008
    Tvs use a system of magnetic fields to deflect the electrons movement inside a tv tube. When the vertical delfection goes bad, usually a failed chip or a dry capacitor, the tv looses the ability to aim the electrons in the tube up or down. This will eventually be just a single straight line through the middle of the tube. Capacitors are mini batteries more or less, they have an electrolyte in them, when they get oldthis electrolyte dries out and the capacitor loose the abiliy to hold a charge. They eventually strt to leak current and short out or open effectivly killing the circuit. When they short its an overload and the tvs circuitry is designed to protect itself, it does this by shutting off if something is wrong.
I have a phillips ptv836 the power button lights up no pic or sound why
Check on the site www.tvrepairkits.com for your model. I believe its one of the oines that has a known shinking screen issue...when that issue surfaces one of the other possible symptoms is the TV will just shut down.
Feb 03, 2013 | Philips Magnavox 9P6034C 60" Rear...
Phillips 27ps55s121cc wont turn off w original remote or tv menu is this board level prob?
Yes, the entire main board used to be (you would have to ask Philips) available but we gave up (where I work) ordering them as too many were damaged or destroyed in shipping.
Board level repair:
check fuse
check power supply voltages
check for short to ground at horz. output transitor
etc
Mar 17, 2012 | Philips Magnavox MS3652S 36" TV
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Keeps shutting off till it warms up
Check for bad caps in the power supply
Aug 22, 2009 | Philips Magnavox MS3652S 36" TV
Phillips cineos 52 inch have sound but no picture
i have a 52 projection tv phillip and the pic is off you see three images on the bottom nice pic in the middle and on top a little off.so what is the problem
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Dec 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Philips Magnavox 27MS343S 27" TV Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
