I lose broadband once I diconnect the ethernet cable
I have a Belkin ADSL wireless modem router - all is fine with the cable attached from the laptop to the router and the signal strenght is "excellent" but once unplugged, Internet connectivity is lost
  • 2 more comments
  • Terry McCartney
    Terry McCartney May 11, 2010
    Setup the network so your adsl modem connects directly to the internet slot on your Belkin ADSL wireless modem router, the router will now broadcast wirelessly to the laptop(assuming it has a wireless card) and any pcs in range with a wirekess card, If laptop has no wireless then use another slot(1) on the router to attach an RJ45 cable from the router to the laptop.
  • registerthis
    registerthis May 11, 2010
    You need a wireless card in the notebook to connect wireless.
  • chris grams
    chris grams May 11, 2010
    what OS are you using?
  • Cosma Papouis
    Cosma Papouis May 11, 2010
    Have you configured wireless connectivity?
    Problem Solver:
  • 9 Answers
You are providing the username and password from your laptop. So its disconnectiong when you shutdown your laptop
Try to use the username and pass from the Modem itself .
Hope you can find difference. Thanks
Posted on Dec 18, 2008
When i unplug the cable from my computer i loose internet connection
Unless your computer also has an active & configured wireless adapter, then disconnecting the Ethernet cable between the computer and the router _will_ cause a loss of Internet connectivity.
Jan 10, 2011 | Belkin Basic Wireless Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Belkin ADSL modem F5D5630au4 keeps losing conection
are you running filesharing? sometimes too many connections at once will cause the modem/router to crash and reboot
Oct 18, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have a Belkin router and i don't know hoe to cennect my laptop to my main broadband at home ,what do i do with the yelow cable do i connect the router to my laptop ? I have no clue and it;s really...
Here's how to connect the router.
From your broadban modem, connect the ethernet cable to the Internet/WAN port of the router. Then using another ethernet cable, connect your laptop to port 1 on the back of the router. Now run the setup CD that came with your router. After setting it up, it will tell you to disconnect the ethernet cable from your laptop to try the wireless function. Good Luck!
Oct 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot install my Belkin ADSL modem with wireless G router and wireless G USB network adapter
First plug your router directly into your computer via the ethernet cable that came with the router. You'll want to connect the cable to the port on the router that says "Internet" (it's ussally to the far left when looking at the back of the router) make sure the other end is plugged into your computer's Network Interface Card (NIC).
Plug your computer into the modem via the UBS connection.
Insert the setup cd that came with the router and follow the prompts.
Once configured then unplug the ethernet cable from your computer and plug it into the modem (which should have an ethernet (RJ-45) jack as well as a USB.
Now you can either hook up to the wireless connection using a wireless adapter OR you can plug your computer in with a ethernet cable to one of the outgoing ports on the back of the router.
Feb 23, 2008 | Computers & Internet
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
