Question about Sony Cyber-shot DSC-W70 Digital Camera
CYBER-SHOT DSC-W70 I am getting the following error message my devise....I do not know if this is an error message...but when i turn the camara on it is saying ACCESS....the i get a message to turn the power off and on again...but I am still getting the same (ACCESS) on the screen, and that's all I will see on the screen....do u know y? is there a password I set up by mistake? please advise...
    Sergeant:
    Champion:
  • 326 Answers
Hello LILYD, there is no password. Replacement/realignement of the optical block will solve the problem. Please contact the nearest Authorized Sony Service. The price for optical block (lens) is about 70 Euro (for my account). If you need more info please advice, Arpi
Posted on Mar 17, 2007
  • chaitanyas Jan 09, 2011
    Ok... so My Sony cybershot dsc w55 had the same prolem. I tried hammering and tpping as other forums have written but nothing worked and I found it logically wrong too but it might have been a problem for some other cameras.
    Getting back to reality, I understood it was a memory stick error as I had clicked photos and realised i didnt have a memory card. So all my photos were saved on the internal memory.
    1. Problem 1: Internal memory was full. So i rmoved my SD card , switched on camera. Checked mode where I can see photos and deleted all. YOU CANNOT DELETE WHEN YOU are connected to your laptop.
    2. I tried using another memory stick/sd card and it worked. Then I cleaned the golden part or the exposed part of the memory stick/SD card and wallah my old card was working.
    3. When you are pushing your SD card inside, try pushing it slow. It displays ACCESS when you are pushing it in. (Yeah you have to remove and add the card when the Camera is ON). You will see the "ACCESS" message.Sometimes when you push it right , the access message goes.
    I hope one of the solution wrk for u.
I HAVE A SONY CYBER SHOT DCS W210 WHIT ERROR E:91:01 IN DISPLAY TANK YOU hOLA TENGO UNA CAMARA SONY CYBER SHOT DCS W210 CON EL ERROR E:91:01 HAY ALGUNA FORMA DE SOLUCIONARLO? GRACIAS
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Aug 18, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Where can i buy a sutter button for a sony cyber shot dsc w70
I think you meant "shutter" button. I have the same issue. Have you found a fix yet? If not, I'll let you know if I find a resource for it. Thanks, Trey treyhannah@yahoo.com
Jan 04, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
My sony cyber-shot DSC-W70 is flashing an error code, 91:01, how can i fix it?
Click Menu
go to setup
then go to setup 1
and go to initialize
then click ok and then ok again
put in the right date and time then
click ok
That should fix your problem! ;)
Jul 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Can't get flash to work, get error message flashing on screen
Click Menu
go to setup
then go to setup 1
click ok
Jul 09, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
DSC W70 Cybershot was dropped
My DSC-W70 is problem de turn off ,what im doing
Dec 08, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Camara sony dsc-w80
First are you using a genuine Sony battery if not then get one. if you are it is a faulty battery pack and requires replacement, if under warranty take it back to the place of purchase
Nov 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot DSC-W70...
It's a flash error, something has malfunctioned with your flash and the system board will continue to give this error until reset by service technician
Feb 27, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
System error sony DSC-w70
Try re-charging your battery or you may check your memory stick. If the cause of this problem is by an accidental drop of the device, then may be you suspected right on the lens. It may cause dis a line of gears... ^_^
Jan 15, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
662 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
