Carriage Return Problem
I have checked to the best of my ability the carriage return latching mechanism on the right side. I do not know how to remove the case, which you suggested. This may possibly be the problem: the inside of this machine appears never to have been cleaned! Once I get inside the typwriter and locate that mechanism exactly I will get after cleaning it and use the DW40 At your convenience. Thanks! Raymond
  • 3,594 Answers
First remove the plaen there is a lath at both ends. Then remove the case there is a lever on the inside of both sides of the case, pull both of them to the front and remove the case.
Posted on Dec 14, 2008
Carriage Return Inconsistency
It has been a while since I have seen a #5 Underwood. I think I still have one hidden in the attic that the wife thinks was thrown out long ago :).
The carriage return is done by the lever that pushes a pawl. The pawl engages in the ratchet teeth on the LH end of the platen. If the typewriter has the half-space feature, then it has to roll the platen two clicks (teeth) for a line space. The problems were usually in two places when this didn't happen correctly. The first is that the bushings on the platen were dry and needed oiling. The second was the follow-up roller is not clicking into the ratchet tooth and keeping it latched in the proper position. Because the platen doesn't roll far enough, or is free enough, the roller stops on top of a tooth instead of clicking into the space between the teeth. This can be caused by dry platen bushings, sticky follow up roller mechanism, or weak follow up roller spring. If you roll the typewriter on its back with the carriage all the way to the left, you should be able to pull the carriage return and watch the follow up roller action from underneath (you may need a flashlight). A light weight oil (Marvel Mystery or a sewing machine oil or Triflow) will be suffiecient to fix it usually. Put a few drops in the bushing where the steel platen shaft goes thru the end of the carrier and a few drops around where the mechanism that attaches the follow up roller to the end of the carriage. Roll the platen back and forth to work it in then slide the carriage to the right and do the shaft on the other end and work it again. Hopefully that will take care of it. If it doesn't, then the spring will have to be tightened by removing a loop. Depending on your mechanical ability and tools, that can be an easy or difficult job.
I didn't mean to write a book on the subject. I worked on mechanical typewriters years ago and hated to see them go to the wayside. I usually don't do this, but if I can be of anymore help, email me :cautionflag1956 at yahoo
Hope this helps
Jun 05, 2010 | Brother SX-4000 Typewriter
IBM Selectric III correcting. Carriage return and
You most likely have a broken torque limiter tension spring. We have them in stock but tou must have a good mechanical ability to install.
Jan 29, 2010 | IBM Office Equipment & Supplies
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Was the carriage return ever on the right?
I have worked on typewriters fo 20+ years.
The only typ's I know of that had the return on the right hand side are all the manual typ's
Feb 19, 2009 | Brother ML-500 Typewriter
Coronomatic 2200 carriage return stops advancing
It sounds like you are coming up against your right margin. By hitting release you are merely bypassing the margin. You might try resetting your right margin by clearing it all the way to the right side of the carriage first then resetting it to where you want it.
Jan 28, 2009 | Office Equipment & Supplies
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
Dec 08, 2008 | Office Equipment & Supplies
Carriage Return doesn't work. Everything else works fine; but it will not return the carriage when the return key is used.
check to make sure no forien objects are in machine preventing the carrier from moving, with the mach. turned OFF you should be able to move the carrier by hand from one side to the other
Jul 09, 2008 | Smith Corona Wordsmith 100 Typewriter
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
