Question about JVC AV-27020 TV
Horizontal Light Only
If power is on, horizontal Light only we seeingon screen.
  • jason May 11, 2010
    you have no vertical? and are you trying to repair this yourself ?
    or are you going to have to take it in?
  • 116 Answers
If you have a straight horizontal line in the middle of the screen the vertical deflection has gone out. Itll need to be repaired, the vertical deflection IC is bad. Hope this helps.
Posted on Dec 12, 2008
Power light flashes, tv will not come on
If the power light flashes, it is an indication of shorted component/s on the main board circuit. most probably it will be with its Horizontal Output section. Horizontal output transformer, Horizontal Output transistor etc: Your set need a detailed check up.
Jun 20, 2012 | RCA F36650 36" TV
Distortion, blinking, dark screen - now nothing
at the horizontal deflection yoke! maybe you have defective flyback! or horizontal yoke!
Sep 20, 2007 | Mitsubishi WS-55807 TV
Bush 32inch tv has the power light on but has a black screen help?
Power light is there, and sound is OK, indicates the faut is with the horizontal output section. Check all the components in the horizontal output circuit. Line output transormer should be suspected.
Image of the suspected components attached.
May 08, 2012 | Bush Televison & Video
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
Blank screen but it has sound, when i turn on there is a horizontal line in the center of the screen, before it goes blank but still have sound, i already check all the resistor on both power supply and...
Your fly back, horizontal is in good condition but the possible fault is in the deflection coils or the deflection correction , pin correction section or the hirizontal width coils.
Please check them one by one as they are found along the sides of the flyback sections. check the continuity of the horizontal coils, it can also be a leak/burnt coils that can cause this problem.
Nov 02, 2010 | Sony KV-20M20 20" TV
Screen will not turn on, power light flashes red. Nothing happens when power button is pushed will not turn set off.
try checking first your tact switch or your power button, then next look for open fuses or low ohm resistor on secondary part of your power supply then check your horizontal and vertical outputs for shortage and open circuits check also your horizontal drive stage.
Oct 13, 2009 | Toshiba 32A32 32" TV
We have a Sony Triniton 32 inch TV we bought approximately in 2000. For a couple of weeks we had horizontal lines across the screen, then it just went black, no audio, nothing. Just comes on and off....
It is probably you horizontal output or horizontal output drivers. The newer TVs derive all there power from the horizontal circuit. This can only be fixed by an experienced technician as that area produces in excess of 20,000 volts to light the screen. Don't try to fix it your self as you could cause more damage or be electrocuted.
Oct 07, 2009 | Televison & Video
Screen not coming on
This Chassis line had a lot of issues with hair-line cracks in the Horizontal Circuit along the right side near the High Voltage Transformer and Heat Sink. It has also had issues with cold solder connections in the Horizontal Drive Circuit especially the Horizontal Driver Transformer. These issues have many times caused a massive Power Supply and Horizontal failures if not repaired.
I hope this helps,
Skyassoc
Jul 24, 2009 | Sony KV-32S22 32" TV
No picture in horizontal mode
make sure u have enough light while taking your pic in horizontal mode because the camera is in a different form then usual.
Nov 04, 2007 | Samsung SCH-u740 Cellular Phone
Dell UltraSharp 1504FP Monitor - Blank Screen
well friend if the fuse is the problem, you will not see any power light indicator. probably theres a problem in power supply circuits or most probably the horizontal deflection circuits. which includes the horizontal oscillator, horizontal drive, horizontal output and maybe the flyback itself. but if you dont know anything about this, better bring it to a qualified tv technician. good luck!
May 05, 2007 | Dell UltraSharp 1504FP Monitor
JVC AV-27020 TV Logo
125 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
