Question about RCA D52W19 52" Rear Projection Television
I have a rca d52w19 bigscreen that's 4 yrs old, when u power up the pwr light flashes a few times stops does it again and goes out but the set never comes on. i looked in the back and on the lower left board cp114 was bad, replaced but still not coming on. do u think flyback or ? ps i donot know much about the components, just dabbling.
  • sag529 Dec 12, 2008
    on mine the light comes on then you here like a static sizzle noise then it turns off do you have a solution.
    Genius:
  • 1,199 Answers
The flyback is a common problem with this model
Good Luck!
Posted on Dec 12, 2008
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
I have an RCA D40W135D with ATC221. Will not come
Sounds like the HV splitter, Very common problem with that chassis
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
52" RCA d52w19
About middle of the board you removed the flyback,there is a u shaped heat sink this is in the middle of the board,behind the heat sink is a blue cap 2200 uf ,if the top is pushed up the cap is bad.
Mar 11, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
