Nikon D70s Digital Camera with 18-70mm Lens
Problem for Nikon D70s Digital Camera with 18-70mm Lens
My new Camera burns through batteries more than the old one, how can i improve it?
By LiZzIe - usenet poster
Same Problem
Nov 16, 2007
-   C-765 UltraZoom suddently battery life is reduced to about three shots. It uses 3.7V rechargeable; I have three and all are doing the same. I can remove the battery and immediately replace it and "milk" a couple more shots. Someone suggested that the camera may need updated software.-   Reajust
Best Solution
posted on Aug 08, 2005
Helpful)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
1. Minimize your use of the camera's built-in LCD (assuming it has one) if it has a viewfinder you can use instead. The LCD is the biggest power drain on your camera.
2. Use only heavy-duty batteries (look for ones that say they're suited to digital cameras). Ordinary alkalines won't cut it. Look into upgrading to rechargeable NiMH batteries.
3. If you have or can get an AC adapter for your camera, always use it when downloading photos directly to your computer.
4. If your camera uses PC Cards or SmartMedia cards, get a card reader that will connect to your computer. This will save battery life and improve data-transfer speed.
5. If problem occurs during very cold conditions, warm the batteries in your pocket or hand just before inserting them into the camera and shooting.
Was this helpful?
Yes
No
Solution #2
posted on May 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, but switched to Energizer lithium. I was getting 10-20 shots. I am now over500 and still at full battery life!
Solution #3
posted on Jun 10, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1. The Samsung A55W does not have a view finder and has a large LCD display
2. The Samsung A55W does not have a charger because it use AA batteries. you have to charge them externally. There is a LION battery available but this still has to be charged externally
3. The power on/off switch is tempermental and does not always work first time
Solution #4
posted on Mar 27, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Use the Ricoh Lithium ion rechargeable battery unit and charger. Part numbers DB43 and BJ-2. Then you can forget battery life the DB43 battery lasts 'forever'; I bought 2 (1 as a spare)... but I've never had a problem.
Solution #5
posted on Apr 04, 2006
Not Rated)
BowerR64
Rank: Wiz
Rating: 80%, 973 votes
I read a review of your camera and it says it comes with NiMH if it comes with rechargable you should upgrade to the energize or duracell from walmart or any local electronics store. Everything in the camera needs power but i think the 2 main ones are flash and the telephoto mechanism. Any zomming in and out and using flash when its not needed could conserve power. What type of charger is it? are they charging the batteries up all the way? Do they charge on their own and shut off or do you have to remove them?
Was this helpful?
Yes
No
Popular Solutions for Nikon D70s Digital Camera with
Questions and Unsolved Problems for Nikon D70s Digital Camera with
Do you recommend Nikon D70s Digital Camera with 18-70mm Lens?
Answer
Answer
CHA display were the counter numbers are
Answer
after i take a photo a " job nr" is flashing on the lcd display and it looks like it takes... (More)
Answer
my nikon d70s will not turn off, when i switch it off it remains on, it still functions as if it's... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D70s Digital Camera with...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
