Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Zenith power will not stay on
TV will stay on for 20 seconds go blank, but can turn it back on, but again the screenb goes blank
  • 1 more comment
  • borlausa Dec 12, 2008
    picture looks perfect, it just won't remain on. It turns off then it can be turned back on
  • Justin Washburn May 11, 2010
    any sound when it comes on?
    what does the picture look like when it is on? Normal?
  • Zenith Master
  • 5,138 Answers
Either replace Lamp or Fan is bad.If lamp has been replaced its the FAN, fan must run at all times in order for set to come on and lamp to stay on.
Posted on Dec 12, 2008
When I turn on my Zenith Plasma it flashes for a split second and goes blank. No picture or sound. I have tried a different power cord but to availe.
My 42" zenith would try to turn on then go back off. LED would go red back to blue. I replaced the YSUS board and it works again.
Jan 10, 2013 | Zenith Z50PX2D 50 in. Plasma HDTV
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Power off automatically, the red light in front of the tv blanking, remote / button can not shut off tv, only unplug the power. After 20 seconds replug the power, tv turns normal, but it happen again and...
Good Day,lizbg;
Check the solder connections at the negative side of both C809 and C810. Resolder if necessary. This a common problem with model.
Good Luck, Big Irish.
Jun 14, 2008 | Toshiba 42H81 42" Rear Projection...
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Tv wont come on
Hi sunny212
1) your tv have it problem in the power regulator you need check
the voltage
should will be 130v no more
2)also check the b+ voltage 180v in the seccion color output
may be is aussent voltage
or open resistor near to flyback transformer
Nov 25, 2007 | Sanyo DS20930 20" TV
Zenith R56W36 56..... Wont stay on
seems like aging problem , your best bet its to replace the deflection board, let me know if you need more info
Jun 10, 2007 | Zenith R56W36 56" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
