Question about Canon imageRUNNER 400S Copier
How to do rip and hold for 1r400
I am having iR400 and set as a network printer. Ican't rip and hold with the use of Command workstation. Printer will print directly without holding the job. I want to know that how to set rip and hold function in command work station
  • 103 Answers
Command Workstation Use For Xerox Not For Canon. OK
Posted on Sep 22, 2009
  • 117 Answers
You want to print to the hold queue instead of print. In windows you can go into your printers and faxes control panel, right click on your printer and select properties, select ports tab, press configure, set for LPR mode, set LPR queue to "hold". (no quotes)
You may also be able to change queue in the print driver.
Consider also verifying that you have the newest version of your drivers for this unit.
Consider getting a 5185i-H1 v2.0 they rock
Posted on May 06, 2009
I am getting a 'disk full' message on the Fiery. How do I delete it?
This chapter provides troubleshooting tips.
Troubleshooting the Fiery
Startup diagnostics are described in the documentation for service technicians. Contact your
authorized service/support center if you see error messages while Command WorkStation is
starting or if the Fiery does not reach the Idle state.
Runtime error messages
For error messages related to canceling jobs and printing, including the Disk Full message and
alerts to load media, see Command WorkStation Help.
For error messages related to the copier, see the documentation that accompanies your copier.
You can turn on PostScript error reporting as a print option from Mac OS applications.
Printer not found
Most failures to find a printer on the network are due to conflicting or missing name or
address settings for the Fiery. You must type names in specific places. The required names are:
•TCP/IP host name (also known as the DNS name), which is defined by your organization.
Type the host name as the Server Name in Fiery Setup.
•Remote printer (internal machine) name. Use one of the following:
NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you
must reconfigure one of the utilities on each workstation.
Dec 12, 2015 | Xerox DocuColor 242-252-260 PS
We need to get the printer to recognize the network server name or IP address. At present it says "Unable to connect to (DC-260-795622). The server name or IP address may be invalid.
Ensure that all your network settings on the printer are correct, especially the DNS settings. Are you able to ping the printer from a workstation? Maybe you have a bad cable connecting the printer.
Jan 21, 2015 | Xerox Office Equipment & Supplies
I have a retail store with 7 x Win 7 Workstations. i have 1 x Epson Tm-T88iii thermal receipt printer connected and installed on lpt1 port on my 1 workstation. We use a Dos application for our sales. The...
Hi, details below for creating a ersistent connection from LPT1: to you \\computer\\printername printer. Do the following on the other workstation that is not printing.
Use the net.exe command to establish a persistent connection.
To do this, use the following syntax at a command prompt:
net use lpt1 \\printserver\sharename /persistent:yes
where printserver is the print server that is sharing the printer, and where sharename is the name of the printer share.
For example, to map LPT1 to a printer shared as Laser1 on a print server that is named Pserver, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. Type net use lpt1 \\pserver\laser1 /persistent:yes, and then press ENTER.
4. To quit the command prompt, type exit, and then press ENTER.
Note In Windows XP, non-administrative users cannot map an LPT port to a network printer path when the LPT port exists on the computer as a physical parallel port.
Apr 12, 2011 | Epson TM-T88III Thermal Printer
What does kyocera command workstation do
I beleive you are refering to the Cammand Center which is a web interface to your printer and it's network interface. You put in the IP address of the printer into your web browser and you can make changes to the printer.
Jan 11, 2010 | Kyocera FS-2000D Laser Printer
I have a problem with my ir400 i can't connect it through internt
i have a problem with my ir 400 in that not glowing lamp
Aug 31, 2009 | Canon imageRUNNER 400 Printer
Unable to find on network
is the printer connected through a network cable,if yes print a config page through the printer and check the ip/tcp settings from the printer and check it against the workstations
Jun 25, 2009 | HP Color LaserJet 2600n Printer
Command Workstation for fiery x15 look for dc 3535 in support and drivers and the new command workstation is in there
Oct 27, 2008 | Xerox DocuColor 12 Printer
Network printing (network port)
The copier and the workstation should have IP addresses from the same LAN class.
Open any internet browser and try to see the printer's webpage - Command Center by typing the printer's IP address.
If you see it = OK if no then something is wrong with the network ...
If you are using a router/hub check if you have a green light for the printer port at the router/hub and at the printer - ussualy a green light indicate OK
If the cables and the rest of the network hardware is OK do a ping from your computer to the printer.
In windows XP: Start->Run-> type cmd
then: ping xxxx.xxxx.xxxx.xxxx
whre xxx = printer IP address
you should see a replay if everything is OK
A very simple check is to bypass the whole network infrastructure (which may be at fault) by connecting the PC or a laptop direct to the printer using a cross-over network cable. Give a static IP to the printer and a static IP to the computer. from the computer you shoould see the printer webpage (open any internet browser and typ the printer's IP Address)
Sometimes for security reasons routers have ON some filters - check any firewals about MAC / IP filters or ports. To print using the network printer you need to let open port 9100.
Oct 23, 2008 | Kyocera FS-1118MFP Laser Printer
Canon imageRUNNER 400S Copier Logo
182 people viewed this question
old marine
old marine
