Question about Microsoft Xbox 360 Console
Can i plug xbox live ethenet cable into cox cable modem
Do i need router ,,, what is a router
  • pbatemon Jan 15, 2009
    can you ues an usb cord to cannet an xbox360 to cox cabel internet
    Problem Solver:
  • 10 Answers
Shaotim is correct you do not have to have a router to use the Xbox online but if you have a computer you want to use online also then you will need a router... think of a router as a funnel it will allow all of your computers to get to the internet at the same time... most routers have a firewall in them which will protect your computers and your xbox should you also decide to share music, picture, videos, etc from your pc to the xbox
Posted on Dec 12, 2008
  • 116 Answers
Yes you can plug it in directly, i dont think youll need a cross over cable, you can use a router so you can share the connection between several pieces of electronics, if you get a wireless router you wont need ny cables. A router routes data between ether net cable allowing each line access to what ever is on the network.
Just want to know if i can use my internet cable straight to my xbox 360 console or do i need another cable to be able to do that?
Posted on Aug 21, 2009
Xbox showing cant connect to xbox live
Unplug your router and cable modem from the wall power to shut them down. plug in the cable modem and wait one minute. Then plug in the router and wait one minute. Then turn on your xBox. It should connect.
Oct 07, 2011 | Microsoft Xbox 360 Console
I cant set up xbox live
Connect to the Internet The first step is to connect your Xbox 360 console to your Internet connection. Here's how:
  1. Plug one end of a network cable into a port on your router or gateway. You might need a long network cable, depending upon on the location of your router or modem.
    Note If you do not have a router, you can plug the network cable directly into your modem.
  2. Plug the other end of the network cable into the back of your console.
Verify your setup Your setup should look similar to one of the following:
Router connection
connect_router_300px.gif Your Xbox 360 console and computer are both connected to a router. The router is connected to a modem, which is connected to a cable wall jack.
Modem connection
modemsetup_300px.gif Your Xbox 360 console is connected to a modem, which is connected to a cable wall jack.
Jul 27, 2011 | Microsoft Xbox 360 Console
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I have an xbox with xbox live subscribtion and i have sattelite internet. I was told if i got a netgear router i might be able to play xbox live? Is this true?
Actually, just about any newer router will do the job. You can either connect the Xbox console via the Ethernet port on the back or through the Xbox Wireless Network Adapter which you can find at any video game store.
The ethenet cable is the cheaper option as it will only cost you about $3 but your Xbox will need to be close to your computer. The WiFi adapter is about $50 and will allow you to use your Xbox 360 on Xbox Live in other rooms of your house.
Feb 24, 2010 | Microsoft Wireless Network Adapter Xbox...
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Xbox Live On Westell C90-610030-06 Isn't Working
if this is the original xbox you have to use a crossover cable especially if your router is the same as your modem (both the same box) (try google for the crossover cable instructions.) if this is the 360 it should just work, also how is your router plugged into your modem or are they the same thing. If that is the case go get a linksys router and set it up so that your modem-router combo plugs into the linksys router which plugs into your xbox (note that this is a fix for the original to.)
Jan 10, 2009 | Microsoft Xbox 360 Console
Cannot connect my modem to xbox live
Try disconnecting your Xbox from the modem, turn both off, wait 60 seconds.
Reconned the Xbox to the modem, turn the modem on, wait 3 minutes, then turn your Xbox on. That should work.
Dec 28, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
529 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
