Question about Logitech Z-560 Computer Speakers
Shorted Sub-woofer While moving a few things around, the sub-woofer came un-plugged from my PC. Lousy sound came next - think sizzle - and now, no more sound. So, is there something inside the sub-woofer that can be replaced/repaired? Before I pull all the set screws, etc. out? There's no reset or external fude that I can find... Thanks in advance, Monty
  • 944 Answers
Try this site first; http://logitech-en-amr.custhelp.com/cgi-... but it sounds as if something has fried in the amp - if you look inside you may well see some burning marks around some of the components. Another possilility is that the cable being pulled out pulled something inside the speaker that has damaged the cone or more likely the power supply , but the symptoms you describe suggest an amplifier issue, possibly caused by damage to the power supply system. Hope this helps :)
Posted on Mar 11, 2007
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
VS2521
I found that one of the pins of the plug connecting the sub-woofer was bent and the plug was not seating properly deep in to the slot. Every pin has a specific task to the sound system, it seems. I set right the bent pin with a long needle gently and re- plugged in to the woofer's slot. After that every thing works amazingly. All it requires is patience and application of mind for a while exclusively focused on the problem.
Thanks and regards
M. Narayanan
Jan 15, 2010 | Altec Lansing Audio Players & Recorders
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Nov 18, 2009 | Bose Acoustimass 15 System
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
I just moved my stepson's computer and I *think* I hooked up the speakers right. It is a 3pc Insignia speaker set with the floor sub. He had headphones plugged in before. We removed the headphons, and now...
If u have been supplied with a driver cd u  should probably try running the disc instead of sutomatic driver installation by vista.Or maybe u got the jacks mixed up.
check it out.
Mar 08, 2009 | Insignia 2.1 Speaker System (3-Piece)
Subwoofer
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
Logitech Z-560 Computer Speakers Logo
218 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
