Question about Microsoft Visual Basic 6.0 for PC
To open a pdf file from a vb application (path secified)
The path to the pdf file is specified in application
so now when this file name is clicked-->i want that specific file to be opened.
    New Friend:
I want to open pdf files in vb6
Posted on Nov 28, 2012
How can i annimate the gif file in vb
Posted on Dec 30, 2008
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
ON INSTALLATION OF TRIAL VERSION OF PAGEMAKER 7 ERROR MESSAGECOMES SAYING ERROR 115 PLEASE ADVISE
Issue
Error 115 when installing Adobe FrameMaker 7.0 or 7.1 on Windows
Solutions
Do one of the following solutions:
Solution 1:Disable anti-virus applications, and make sure all 3rd party applications are closed before installing.
Solution 2:Copy install files to HDD are run setup from that location (Frame installer lives in FM directory)
Solution 3: Remove all files from %temp% and %windir%\temp and reinstall
Background information
Error 115 from the InstallShield help reads as follows: "Specified file cannot be opened as write. An attempt was made to overwrite a locked file belonging to a file group that does not have the Potentially Locked or Shared property set to Yes; an attempt was made to install a file with a long file name (or to a folder with a long path name) in a 16-bit setup; or the path to the target folder is invalid."
Apr 10, 2011 | Adobe PageMaker V7.0.2 for PC
CHEQUE PRINTING CONFIGURATION IN CANON LBP3300
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size or page setup when printing from an application, taking Adobe Reader 6.0 as an example.
Note: The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note: The printer name displayed in this dialog box can be changed in the [Printers and Faxes] folder (the [Printers] folder for Windows 98/Me/2000).
Jan 27, 2011 | Canon LASER SHOT LBP 3300 Printer
HOW 2 OPEN RUNTIME PDF FILE IN VB 6.0?
A pdf file is a text document and can't be 'opened' as such in VB. Try copying all the text in the pdf file, open VB, start new project, and paste.
Jun 14, 2009 | Microsoft Visual Basic 6.0 for PC
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Name some common dialog boxes and mention its uses.
There are numerous common dialog boxes in windows, please note i am very specific to windows (and not VB since VB has difference nominclature for common dialog boxes)
following are some windows common dialog boxes:
  1. UserInput dialog box: to fetch user input.
  2. Alert dialog box: to display some alert information to the user.
  3. File Open Dialog Box: to browse and open file from selected filesystem.
  4. FileSave dialogbox: to save a file to a filesystem on selected path.
  5. Print dialog box: to setup printer preferences and print setting commands routing to printer.
Thanks.
Mar 07, 2009 | Acer Computers & Internet
'unable to save file. the system cannot find the path specified'
Had this same problem and just fixed it. You need to actually change the button settings in Navigator. Open MP navigator and choose One-Click, then click Button Settings. You can choose a new save destination from here. Even though you are using the software instead of the button on the device, it works.
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Please check the location where the file saved by your Scanner and note down its size.
Also as you mentioned in your next reply, you need to go for check Device manager. Reinstall the drivers.
Let me know if you need further assistance. Don't forget to vote me.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
Windows cannot access the specified device, path or file.
Try to using Admininstrator user and passwor or the user id and password which have preveleges.
Thanks
Iqbal
Jun 16, 2008 | Acer Aspire 4315 Notebook
Microsoft Visual Basic 6.0 for PC Logo
380 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
