Question about Sony PS-LX250H Turntable
Low volume on PS LX250h
I just bought my first turntable (a Sony LX250h), as I'm a music fanatic and decided to begin a record collection. With no speakers connected, the volume sound comes clear, but very, very quietly from my turntable, which I assume is the natural sound. When I connect the cords to my speakers, and turn my speakers up all the way, the volume is very low. Low enough that it can't be heard from more than 10 feet away.
From other problems I read, it looks like it may be one of 3 issues:
1. My speakers have a problem playing from turntables? The work very well for my computer, I doubt this is the problem.
2. The cartridge is out of place? I don't know where to find the cartridge, or how to adjust it. I've read that this turntable comes with the cartridge ready to go.
3. I need a phono preamp? I don't know what this is, but if it will fix the problem, I'll go find one.
Thanks in advance!
  • tbiggs0 Dec 12, 2008
    To a beginner like myself:
    Can I get an explanation please? What's a pre-smp? What's a power amp? What's the ground wire? Where do I find these things?
    Thanks!!
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Posted on Jan 05, 2009
    Genius:
  • 1,199 Answers
You need a pre-smp and it sounds to me like a power amp too..the turntable needs connected to an amp (in the phono jacks because they sena a much stronger signal then say a dvd jack...also make sure you have the ground wire from the turntable connected to ground on amp
Hope this fixes ya!
Posted on Dec 12, 2008
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
I have hooked my turntable up to my stereo and even at full volume its extreamly quiet, is there a problem or is this stereo just not set to play records? do i need some sort os amplifier?
Hi, Remove the rubber mat on the platter, there is a toggle-switch for the pre-amp. With the power off, manually rotate the platter and it will become visible through the gaps. This should resolve the low volume issue. Hope this helps. Post back with your results and good luck.
Feb 01, 2011 | Sony PS-LX250H Turntable
When plugged in to amp and eq switch on or off no volume through amp.turn amp full up and very low volume.cd ant tuner fine.just turntablethis is the ps-lx250h
Do you have a phonograph input on your amp? If not you may have to purchase pre amp. What type of cartridge do you have installed on the turntable? Do you have a moving coil or moving magnet cartridge? If you have a moving coil your amp needs to have an input for a moving coil cartridge or you must use a pre amp.
Jul 20, 2010 | Sony PS-LX250H Turntable
Ps-lx 430 1 speaker gives low volume. Otherwise speakers work with other components
This is an old-school turntable so it requires a PHONO input on the amplifier (or a Phono Preamplifier). It will not produce either enough volume or the correct frequency response without it. Google Phono RIAA
Jul 01, 2010 | Sony PS-LX250H Turntable
Tone arm moves to the middle rather than the beginning
There is 33and 45. that's the size of the record.There should be a level to change from one to the other.
Aug 07, 2009 | Sony PS-LX250H Turntable
To backup my lp record collection to computer and CDs, do I need a special new turntable--or can my current turntables be readily adapted to connect with my computer or even thumb drives?
I have a Sony SDLX250H connected to my computer right now, using an adapter for RCA to 3.5mm, into the line in jack. You could do the same thing, and probably use Audacity to do some recording. Wish you the best!
Apr 06, 2009 | Sony PS-LX250H Turntable
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
Jan 24, 2008 | Sony PS-LX250H Turntable
I want to copy some records on CDR but the sound is too low. Can someone help?
If you have and amplifier or reciever you can frist plug your turntable into the amp or rec. and then to your sony CD recorder and then you should be able to adjust your volume to a higher position, also you can hook up and Equalizer and get the needle sound completely out unless your old school and like that LOL. There is also another way to save and make copies of all your old and new records By using the computer and getting a good sound card for your computer unless you have a good one or even buy a expansion bay with remote control made also by sony you can digatally remake all of you albums, Well sorry to go on and on but I am really into doing the same thing , If you need anymore help Please Let Me know Thanks again bear001
Dec 12, 2007 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
692 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
