Question about PNY 8GB USB 2.0 Flash Drive - Blue/Black
How do you password protect a 8G PNY storage device?
I was wanting to know how to password protect the data on a 8G PNY Attache jump drive.
4 Suggested Answers
Damilare
  • 358 Answers
SOURCE: pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Posted on Oct 31, 2009
Testimonial: "Thank you so much! This fixed my problem and I now can use 7.5Gb of my flash drive!(I do wonder why it says 8Gb, but I can only use 7.5)Again, thanks!"
  • 66 Answers
SOURCE: PNY Attache driver
type this link in your address bar http://list.driverguide.com/list/company831/, then chose the hardware you want a driver for ie attache' driver - then click on it, chose the line under filename, for a free download chose free download but view some adverts, click no thanks at the bottom of the ads, two in all, type the three letters you see and enter, then you can chose the destination of the .zip Once downloaded run it and you should install your hardware.
Posted on Jan 29, 2008
watcher26
  • 141 Answers
SOURCE: need driver for pny mini attache 2.0
Here are a few possible sources for your driver software :
http://en.kioskea.net/guide/905619-pny-pny-mini-attache-4gb-usb-2-0
www.paretologic.com/lp/drivercure
http://www.helpdrivers.com/ingles/listado/panel.asp?marca=PNY&perif=otros
http://driverscollection.com/?V=PNY&S=48
try these sites they should provide you with success
Posted on Jan 04, 2010
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Can I use my PNY 2G on my tablet and what it will do ? Ihave a Acer tablet Android
Most tablets dont have the option to plug in an external USB stick. Your best option to transfer data is to either plug them directly into a computer or use email.
Dec 29, 2014 | PNY 2GB NEW ATTACHE USB FL DR
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
PNY Attache 64GB usb flash drive Disk is write protected
Normally I'd make something this simple the very first step. Some USB flash drives come with mechanical switch on them that put them into Write Protected mode.
There can be very small slider switch.
And if this is the case, then you must move the switch to unlock position.
Source: http://www.rescuedigitalmedia.com
Oct 01, 2012 | PNY Attache 64GB USB Flash Drive
Dont know how to delete the pictures off of it.
You can do it to ways
Open up My computer
open removable storage drive may be called PNY or something like that.
right click and delete a file
or you can hit the delete key on the keyboard
Note:
If the need to delete multiple files simply hold the left mouse button and drag a selection box around what you want to delete. Then do one of the above Delete commands.
Jun 08, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
Pny attache optima pro 8g usb drive disk space problem
Goodluck
Oct 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Clear memory stick
The easiest way is just select all and delete
Mar 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
1,999 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
