I want to take pictures to show on a LCD monitor and have it take up the entire screen rather than black on the sides
SOURCE: LCD SCREEN WONT WORK
Here's the official letter from Fuji:............... FUJI PHOTO FILM U.S.A., INC. announces that some of the FinePix A303, F410, and F700 digital camera models may develop a problem with the CCD imaging sensor. However, the problem affects a limited number of units and may not occur in all cameras. The symptoms are captured images that appear completely black, have a purplish cast or multi- colored distortions. These symptoms would be seen on the camera LCD monitor when the camera is in the shooting mode or during playback. A limited number of these models will have these problems. Your camera is certainly giving the signs of a bad CCD but it's not on Fuji's list. But don't worry I had my 602Z fixed for free out of warranty and there's plenty of reports of other Fuji models not listed being repaired. Email Fuji and explain what your camera is doing and as long as you have the warrabty card and proof of purchase they should help you out. GOOD LUCK
SOURCE: fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
SOURCE: FUJI FINEPIX S5000 - Screen purple in Camera mode - No picture
This is a chip problem... My FIRST S7000, had this problem, and I had it replaced by Fuji {out of warranty}, now today, the SECOND S7000 is doing the exact same thing!
Contact Fuji at their New Jersey offices for info on how to get your camera repaired.
SOURCE: lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
