Question about Sony Playstation 3 (PS3) Console
Ps3 handset will not charge
When i use the usb cord to try and charge the handset i get a message saying the maximium USB usage has been reached and to remove a device, but i dont have ant other device attached.
what do i do?
    Problem Solver:
  • 6 Answers
Get new controllers
Posted on Dec 13, 2008
My Tab will not start, I receive two different "draw failed" messages...if it is charging, it says, 'charging_7.jpg' draw failed. If the USB isn't plugged in the message is logo_expresso7.jpg draw fai
It sounds like the system image (operating software) got corupted and need to be re-installed. If you haven't got a backup image of your tablet, then you need to take it to a cell shop so they can re-install your OS (Operating System) software.
Mar 19, 2014 | Samsung - Galaxy Tab 2 7" 8gb Wifi
I have Sony NW-E503 (256 MB) MP3 Player. I have a problem when am charging my walkman I get a message "CHARGE ERROR". Can someone help me solving this problem? I am charging my player with...
I'm sorry that the Player is not charging as expected. It is possible that the usage of non-original cable will give the Charge Error. Please follow the below troubleshooting steps and check the operation before purchasing the original cable to make sure that the issue is not with the player or the connectivity.
  1. Please make sure that the USB connection to the Computer is secure and firm.
  2. Try connecting the player to a different USB port on the Computer.
  3. Avoid connecting to USB hubs.
  4. Try removing other USB devices otherthan keyboard and mouse.
  5. Restart the Computer and try again.
  6. Try connecting to a different Computer to confirm the issue is not with the Computer.
Thanks for understanding. Please let me know if you require any clarifications.
Oct 18, 2011 | Sony NW-E503 (256 MB) MP3 Player
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
How do I charge my 1808L mp3 8gb portable media player
You should have received a short USB cord with your 1808.
First, turn the mp3 player OFF.
Next plug the small end of the cord into the bottom of the 1808.
Then plug the other end into any USB port of your computer.
You should get a popup message saying that your computer has found a new device, if not, after one minute, turn on the 1808.
The mp3 player charges any time it is plugged into the USB port,
Jun 07, 2010 | Eclipse TCH828 Digital Media Player
Problem with USB cord, but the usb cord fits in printer and laptop fine. Computer screen says Printer ready, but when I try to print a message says check USB cord. Don't understand
Try using another USB port if you have one. If the others are full, disconnect one of your devices from the USB port and try your printer there. For some reason, switching the USB port sometimes makes devices connect. Good luck!
Mar 13, 2010 | Lexmark X2600 InkJet Printer
My GPX ML648S MP3 player turned off while charging and won't turn back on. What do I do?
are you charging with your computer through the USB cord or did you get an adapter to charge via an outlet?
If charging with your computer, it could be a bad USB port, try the ports in the back of the tower if your using the front and vice versa.
Is the device responsive otherwise? Can you load music and the like while the device is connected? If not your USB Cord could be faulty and need to be replaced.
If you are using a laptop keep in mind that sometimes the amount of voltage required for this device does not always reach the USB ports. Try disengaging the laptop battery for an hour and then reconnecting it.
Mar 12, 2010 | GPX ML648B MP3 Player
My Laptop won't read my Creative 2GB Player
Try to use another USB cord maybe the cord you use is faulty already so try to use another. Use also the other USB port.
Jan 28, 2010 | Creative Technology Zen Stone Plus 2gb Mp3...
Belkin Wireless USB Adapter not detected!
This device is well known for the high level of current draw that it requires in order to work. I would suggest that you remove all other unnecessary USB devices and try the device again. It is more than likely that your system will find the device.
The quickest way of ensuring continued usage, when you have numerous USB devices, is to purchased a powered USB hub and ensure that the Wireless adapter is connected to one of the powered USB ports on the hub.
Hope that helps.
Aug 26, 2009 | Belkin (F5D7050) (F5D7050VSNPDQ) Wireless...
I purchased a new laptop, the usb hub cord is not long enough to reach my usb slots on the laptop so I purchased a usb extension cord 3' from radioshack, but when I use it vista says it does not recognize...
You may need a 2.0 USB cable. Read on:
The cables will most definitely look the same. That's because the connectors didn't change between USB 1.1 and 2.0.
But not all cables that look the same are the same.
A higher quality 1.1 cable stands a better chance of working at 2.0 speeds. What do I mean by quality? Well, it's nothing that's visible, I'm afraid. It has to do with the quality of the wires used and especially the shielding against electrical interference. Higher speeds are more susceptible to interference and noise - either from the outside, or from the USB signals themselves.
I also say in "typical" usage, because not all scenarios are the same either. For example a short cable is more likely to work than a long one. If you have an electrically noisy environment that might cause problems.
And of course the devices themselves play a big role. Some devices are more tolerant of weak or noisy signals than other. Purchase a 2.0 USB cable, it is not expensive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | Computers & Internet
Panasonic cordless phone KX-TG5766C
The cable connected message is a problem. Do you have a USB/Data cable to sync your phone to your PC with, if so you could try that and see if the PC recognizes that the Phone/Device is connected and then eject it (by right clicking it's icon in your sys tray) properly. That may clear the USB message.
As for the charging problem, it is probably directly related to the message issue. I can only think of trying another battery and or charger if it still doesn't charge if/when you get the USB cable message cleared.
I must admit though that from your description of the problem my first impression is that the phone must have been dropped or possibly got wet, is either possible? What is the make and model of the phone, as the cordless phone listed above I wouldn't think would have a sync cable port?
Mar 20, 2008 | Lands Phones
Sony Playstation 3 (PS3) Console Logo
310 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
