Question about Philips SA5125/37 MP3 Player
I AM GETTING AN ERROR MESG TELLING ME TO USE DEVICE MANAGER TO FIX MY PROBLEM BUT I DONT UNDERSTAND
  • 36 Answers
Right click on icon at bottom properties
Posted on Dec 12, 2008
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
I have a slimtype dvd a ds8a2s a ata device that I get a code 10 device cannot start message in device manager I have tried to re-install the driver and downloaded any updated drivers and get same message
From your description I understand that the DVD drive is not working and you have code 10 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Jan 10, 2010 | HP Compaq Presario CQ60Z Notebook
Psp update problem
DNS error 80410414 means the web address was typed in wrong eg: i tryed every thing when this mesg came up, then when i nearly gave up i typed www.facebook.co.uk and it changes the address to http://en-gb.facebook.com/ the psp cant do this so it just gives an error mesg
i then typed in the address on my psp the exact address; http://en-gb.facebook.com/ AND IT WORKS :) WOWO :)
rate it if the problem resolves
Jan 09, 2010 | Sony PlayStation Portable (PSP) Slim...
Base system device and network controller driver error in device manager at win XP
"Base System Device" is your card reader, I had the same problem. If you dont use it jst disable the device, otherwise the drivers should be on your alienware Master CD, if not get a tech support guy to send 'em to you.
May 25, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
My yahoo instant mesg has stopped working
Re-open it log in and go to help; update
You need the latest updated version.
Cheers.
May 14, 2009 | Yahoo Messenger
System did't found audio driver
my sound is not installed and i no have suporrt sound drive
Feb 01, 2009 | Altinex DRIVER/GLI CARD, 2-IN 2-OUT,...
Web cam not fond
Did you install the drivers for your webcam. Check in device manager if there is an exclamation or question mark against the webcam.
Jan 26, 2009 | Acer TravelMate 341T Notebook
A problem with my philips gogear...
The Device Manager came with the installation CD. If you lost the installation CD, you can get the Device Manager by going to www.usasupport.philips.com and entering in your model #, and going to "software & drivers"
If Device Manager is already installed, you can find it by going to Start --> All programs --> Philips Digital Audio Player --> Philips Device Manager
Jun 22, 2008 | Philips GoGear HDD6330 MP3 Player
Need help
If your computer is a Windows ME/2000/XP/Vista it does not need any additional software.
Remove any camera associated software and simply plug the camera in- The Camera/Scanner Wizard will come up and ask what it is you want to do.
Let Windoze do the work.
If you sill get this message go to Control panel/system/device manager and check the USB devices for any yellow error signs.
If you have one come back and tell us about it.
Dec 18, 2007 | Cameras
Philips SA5125/37 MP3 Player Logo
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
