Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer has a mind of it's own, cannot change contro
Our Whirlpool Duet Dryer (GEW9250P) sometimes works fine and sometimes we cannot change any of the settings nor get any of the buttons to work. If we shut the door hard, it may work.
Is this the control panel?
How do I diagnose this?
  • Debi71 Dec 13, 2008
    yes except mine will not come on at all no lights we have tried the breaker. no luck where are the fuses?
  • jeffleusch Dec 18, 2008
    I took mine apart and luckily found out that the ribbon cable was partially disconnected. Put it back and it's working great. So nothing to buy!
  • 113 Answers
First of all check to see that the control panel is not locked. There is a lock button assigned on the control panel. It should say it next to one of the buttons. Not door locked. You have to hold that button in for 5 - 10 seconds to unlock the panel. If not, you may need a new panel, happens often, its part # 8558753 depending on the color. Thanks Dave www.washermd.com
Posted on Dec 16, 2008
  • Dave Dec 18, 2008
    Sorry there are no fuses to reset on this. Best bet would be to take the top panel of via 3 screws on the back and check the panel for any loose connections at the board. Make sure its unplugged first. This is a sign of the board going bad. May have to replace the board. Pretty simple. Hope this helps. Dave www.washermd.com
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
I have a Whirlpool Duet dryer it is not heating everything else works
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Whirlpool GEW9250P Electric Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Oct 31, 2009 | Whirlpool GEW9250P Electric Dryer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Can I reverse the swing on my Whirlpool Duet Washer and dryer?
Yes they can be reversed. Some models require a kit with handles and trim pieces. Get the model# and I can try and look this up for you. Vic
Jun 28, 2009 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer GEW9250P (electric)- how do i unlock dryer?
its a botton to the far right that says child lock,,,press and hold for 3 seconds,,if this doesnt work un plug it for a minute..than replug
Dec 19, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9200L00 Electric
the dryness sensor is bad, replace them and it will be fine ,,, Larry
Nov 01, 2008 | Whirlpool GEW9250P Electric Dryer
Dryer dead
you have no power to dryer ,,,, turn the breaker completely off, count to 30 and flip back on ,,, should work, if not replace the breaker
Jul 03, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
266 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
