The sensor on my Toshiba 46h83 TV does not work with the remote or with any remote for that matter. can it be reparied
  • 905 Answers
Yes , this can be fixed
it may be the sensor but it may be the crystal or eprom , so testing will need to be done to find out which one and if there are bad values on any other components in the circuit
Posted on Dec 12, 2008
Have vertical lines across the tv. Started as something that happened right when I turned the tv on (for 5 mins or so). Now it's all the time. Toshiba 46H83
you more than likely have a bad panel inside of your tv. you can have someone repair it but it's not recommended as it's pretty expensive. You should just invest in a new tv.
Jul 23, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Can you connect macbook to Toshiba 46H83 projection TV
"This TV is not intended for connection to and should not be used with a PC (personal computer)". This statement should say it all.
Dec 19, 2017 | Toshiba 46H83 46" Rear Projection...
Remote range 1 ft.
Try putting in a new set of batteries.
May 19, 2009 | Toshiba CT-90157 Remote Control
Toshiba 46H83
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
May 13, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Nov 14, 2008 | Toshiba 46H83 46" Rear Projection...
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
