Question about Goodman GMS90703BXA Heater
Pilot on water heater is going out when furnace turns on!!!!
I recently had a Goodman Furnace put in. It was a change out. The old one was a Carrier. Every time the furnace kicks on the flame goeas out on my water heater. IT seems like the exaust tube is blowing air down the exaust of the water heater and sucking the flame out. I am baffled please help me....
Thanks Brock
    Problem Solver:
  • 11 Answers
Contact the furnace company and let them solve your problem free of charge
Posted on Dec 12, 2008
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Carrier super saver furnace keeps going on and off
Sounds like the flame sensor is dirty or bad. This sits in the burner flame when the burners are running. This usually has a single white wire connected to the back of it.
Jan 03, 2010 | Dayton Gas Furnace Heater
Pilot light does not stay lit
check that pilot flame is in contact with the thermocouple the small copper cylinder if not properly burning against adjust if flame is good and the therm/coupl is not covered in soot(wipe clean if has build up)thermocouple gone bad replace
Oct 28, 2009 | Goodman GMS90703BXA Heater
Heater won't heat very long
there isnt a pilot if it has jets , it has a Hot surface ignitor. you should see a glow and then the jets light , if its running for a few min it may be overheating, have you changed the filter recently? you should also have a flash code you can locate when the furnace shut off and is no longer doin what its supposed to look thru the bottom door peep hole and watch for a series of red flashes. if you remove the cover after retrieving the flash code there will be a chart on the inside of the cover that will tell you why the furnace is shutting off. by the way the model # you gave is for the A/C coil above the furnace, not the furnace.
Oct 10, 2009 | Heating & Cooling
How do I relight Pilot for a Model # Carrier 58GP100-3 Furnace?
as the unit is very old there is no specific manual available for it to guide you but i will give u some link for extra help.
Nov 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
No heat!, light blinks 3 times
Make sure the inducer motor is free of condensation and that all water is able to drain out. Unfortunately your furnace is a lower-grade “builders” model and does not have the same quality of components and workmanship as a Carrier or American Standard furnace. Prior to these failures, It was about 1/2 the price of the units mentioned. And the warranty drops off quickly. You get what you pay for.
Contact Goodman to see if they will cover the cost of your parts at 1-877-254-4729 US only. Their own motto is “Quality Makes the Difference”. It sure does.
Nov 25, 2007 | Goodman GDS81155CNA Open Flame Mid-Size...
Goodman GMS90703BXA Heater Logo
96 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
