Question about ATI Computers & Internet
Problem installing PCIe graphics card
I have a dell gx280 and i am trying to install a visiontek ati radeon 3850 graphics card but my power supply doesnt have extra 4 dot cables to connect to the graphics card. What can i do to try to fix this
    President:
  • ATI Master
  • 1,314 Answers
All you need is an adapter cable like this.
Thanks and please take a moment to rate as fixya.
Posted on Dec 12, 2008
Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
No video
HI,
You can go into the BIOS , under onboard devices. Change the primary video controller to PCI.
refer to the following screen
http://supportapj.dell.com/support/edocs/systems/dim4700/sm/syssetup.htm#wp1052347
If the cards are not detected on the board. Then the problem could be of the PCIe slot .
Thanks
Proton
May 25, 2009 | Dell Dimension 4700 PC Desktop
Problem installing ATI Radeon X1300 256mb in Dell Optiplex GX260
Hi edward,
I'm looking at the specs of your dell and of the video adapter.
It appears the Power Supply in your dell may to under powered for the video card.
According to dell's website the largest psu that ships with that unit is 250 watts while the radeon x1300 needs a minimum of 250 watts to run and assuming you have the 250 watt version you need to take into consideration that the psu is also powering your CPU, memory,fans,hard drive/s and other components on in your system so 250watts just isn't enough.
You may want to contact dell and see if there is a larger psu that you can purchase. I would recommend one at least in the 400 watt range.
I hope you get it straightened out I certainly know how frustrating it can be to not be able to use new hardware.
Let me know how it works out.
Sean
Mar 16, 2009 | Computers & Internet
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Comparable cards to the ATI All In Wonder 9700 Pro 128 MB
Hello there. The Radeon 9700 Pro was a high end graphics card in its time. Today the latest Radeon cards are 3870X2, 3870 and 3850 models. The 3850, while mid-high end range, would be a substantial upgrade from the Radeon 9700 Pro.
If you are planning to upgrade your system, make sure you choose the correct type of card (AGP/PCI-E) and that your current system has a good enough power supply to power a new upgrade.
Hope this helps.
Apr 13, 2008 | ATI All-in-Wonder 2006 PCI Express ,...
VisionTek x1650 xt Quad video card
please read it.
http://www.visiontek.com/teksupport/pdf/X1650_quad_quick_install.pdf
this can resolved the matter
Sergio
Mar 04, 2008 | VisionTek ATI RADEON X1600XT 512MB Graphic...
Sapphire ATI RADEON 3850 PCIE 512mb---> Having problems with card driver. PC slows down whenever such driver is installed, both from supplied driver cd and downloaded driver from sapphire/ati website. I am...
JoBal,
The main problem is meeting system requirements for this high-end card. Please see the requirements list below and let me know if you are up to par.
Requirements (taken directly from their website)
  • PCI Express based PC is required with one X16 lane graphic slot available on the motherboard.
  • 1GB or greater system memory for better performance.
  • 450Watt or greater power supply with 75 Watt 6-pin PCI Express power connector recommended.
  • For ATI CrossfireX: 550 watt power supply or greater with two 6-pin connectors.
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Installation software requires CD-ROM drive.
  • DVD playback requires DVD driver
  • Blu-ray/HD DVD playback requires Blu-ray/HD-DVD drive and playback software.
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 3850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per board are required.
Take care!
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
