Question about KitchenAid 24 in. KUDU02FR Built-in Dishwasher
Kitchenaid Superba Dishwasher
After my KitchenAid Superba dishwasher has run its cycle, the soap door is open but the dish soap, either granular or packet, is still dry and intact. Although the dishes appear to be clean, they obviously haven't been washed with soap! Is there something I can do to fix this myself? This dishwasher is almost 4 years old and has worked fine until lately.
  • 1 more comment
  • ItWorked4Me Aug 19, 2008
    1. I had a similar problem with my KitchenAid Superba. The only thing is that I found that the small top arm was not emitting water nor was it spinning.  I tried a few times to run the machine with nothing in it but a cup of white vinegar ... and still no help.  Then I took out the top shelf and clogged the hole that the middle arm runs from with a wide strip of tape... and still no help.  I took a tooth pick and cleaned out the small top arm's holes and as I did that I noticed that the top arm was not properly snapped into it's place. I ran the machine and saw no movement in the arm.  Then I snapped the arm into it's hinges. There are two hinges holding the top arm in place.  I tried the machine again and WELLA! - I opened the door to see water streaming from the top arm and it still spinning a bit.   My machine is fixed!!!
  • reallyfrustr Dec 07, 2008
    My dishwasher (kitchenaid superba) no longer has water running through it . i have tried the rinse cycle but no water appears in it. Also prior to this there were always debris and bits dried onto all our glasses. What can be causing these two problems?
  • Anonymous Mar 13, 2014
    noise
Also had the same problem with our KitchenAid Superba. A plastic cutting board had been placed at the front of the lower basket and was partially blocking the soap dispenser door! My advice: Be aware of large pans or cutting board placed nearby the dispenser.
Posted on Jun 16, 2008
I had the same problem wit my Kitchen Aid superba. All I did was throw a dishwashing tablet in the bottom of the machine before using. Worked fine for me. And I didn't have to go through the hassle of taking half of the machine apart. I've also seen a lot of complaints posted on other web sites regarding the superba dishwashers. I'll never get another one that's for sure!!!
Posted on Nov 06, 2007
    President:
  • 878 Answers
Gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
Soap not fully rinsed from dishes, maytag quiet series 300
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 12, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
The soap dish doesn't always open during the wash cycle
Make sure your dishes are not blocking the soap door. I have found that we have to make sure that taller items are pushed to the back of the dishwasher.
Jul 19, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
HElp Dishes not coming clean
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
KitchenAid 24 in. KUDU02FR Built-in Dishwasher Logo
2,447 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
