Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer Ultimate Care II drains but doesn't spin. Loud grinding noise. Is it the coupler or the transmission? Or something else. The machine is probably a 2004. We bought new March 2005.
  • 5,911 Answers
The coupler would be an easy assessment to consider. The following link explains how:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
I posted the link that explains how to replace a coupler, because it also explains how to get to it. It is common for these couplers to break over time. Either, the plastic pieces break, or the rubber bushing shears apart. A common sign is to find black filings under the washer. Another common problem with earlier models, is the center hole in the coupler rounds out and begins to slip on the transmission or drive motor shaft. The manufacturer has come out with an improved coupler that has a steel grommet in the center. The part number is provided with the link. I hope this helps you. Let me know if you require further assistance.
NOTE: If it is determined that the coupler is NOT bad, the gearcase (transmission) would be your next logical choice. I can also explain how to replace one of these (if required). It's not a difficult job.
Posted on Dec 12, 2008
My washer will wash, rinse and spin but after it spins it makes this really LOUD grinding noise and shakes. What could it be?
Rebuilt transmission or bad coupler, to check coupler remove pump & motor from
transmission see if it is toast.
May 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Just moved my whirlpool ultimate 11 washer to clean floor and found very dark grease like substance under the machine with tiny bits of particles. Machine makes alot of noise when spinning. I just put in...
its is indeed the coupler
thats is usually exactly what we look for when we inspect them
i risk a bad rating, but i would at the very least inspect the coupler,
barring that, your transmission has popped a leak
and your hearing a grinding from the clutch or brake
Oct 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine wont wash
needs a new motor coupler. small round rubber piece between the motor and transmission. easy to replace
Oct 29, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate Care II will not spin and makes a loud noise, I did get it to drain the water.
The usual culprit is the motor-transmission coupler. This is located between the motor and the transmission. You need to remove the pump and then the motor to access it.
Oct 17, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal De
