Question about Performance Teknique ICBM-5712 Car Subwoofer
Im trying to find RMS specs for PERFORMANCE TEKNIQUE CBM-5712 SUB
I have a pair of performance teknique CBM-5712,its say its 500 RMS and 2/4/8 ohm operational.so my questionis what are the actual RMS spec's?and what is the best way to wire ?i just want to know my options if i want to wire it 2/4/or 8 ohm and what RMS would i get per..thank you jesse_m_1414@yahoo.com please contact me if you can help.
  • 58 Answers
WELL FIRST IF THEY ARE DUAL VOICE COILS, IF SO,TO GET 2 OHMS JUS THOOK THEM UP TO ONE OF THE TWO TERMINALS, IF YOU WANT 4 OHMS HOOK YOUR POWER LEAD TO ONE TERMINAL THEN ABOUT THREE FEET OF WIRE COMING FROM YOUR LEAD TO THE O9THER TERMINAL, IF YOU WANT 8 OHMSHOOK YOUR POWER LEAD TO + ON ONE SIDE THEN THE NEGITIVE LEAD TO THE - ON THE OTHER SIDE, THEN VISE VERSA. BUT IF I WHERE YOU MAKE THEM 4 OHMS
GOOD LUCK
Posted on Dec 12, 2008
Whats the RMS Watts on a Performance Teknique ICBM 5910 I know it has 1500w peak but I'd like to know the rms watts on the subwoofer
Personally, I would not put more than 500 RMS total to that sub. 300-400 RMS is more like it.
Jan 05, 2014 | Car Audio & Video
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
    You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
    Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
    Can i hook this amp to a 2 channle out put stereo?
    Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
    Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    No knowledge of how to hook two subs which are the 12 alumni audiobahn sub to a performance technique 781 mono block amp operation ohms for the speakers say 3 or 12 ohms during operation can i bridge or do...
    yor subs have dual 6 ohm voice coils from the sound of it-your amp is rated at 650 watts rms at a 1ohm load. The best you can do with the equipment you have is to wire ALL the coils of your subs in parallel and that will give you a 1.5 ohm load for the amp.It should knock the hell outta them with 300 watts on each sub - good luck
    Jan 14, 2010 | Performance Teknique ICBM-782 Car Audio...
    NOT SURE WHAT OHMS SUB I NEED!
    if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
    Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
    I got a performance teknique power amp its 1700 rms at 1 ohm i need 1500 rms at a load of .67 will be ok
    No, with 1700watts at 1 ohm the max current is 41 amperes, with 1500 at 0.67 the currents is almost 48 ampreres, you will be overdriving the amp at signal peaks.
    Apr 08, 2009 | Performance Teknique ICBM-782 Car Audio...
    I need rms spec's for performance teknique CBM-5712,
    you will get more power at lower ohms, the lower the ohms the less resistance it will have against the amplifier
    heres a small definition if it helps
    The ohm is defined as the electric resistance between two points of a conductor when a constant potential difference of 1 volt, applied to these points, produces in the conductor a current of 1 ampere, the conductor not being the seat of any electromotive force.[
    Dec 12, 2008 | Performance Teknique ICBM-5712 Car...
    Performance teknique ICBM-5612
    Whats yhe Rms on this sub? Which is better compared with the 5712 modle?
    Mar 22, 2008 | Performance Teknique ICBM-5612 Car...
    Performance Teknique ICBM-5712 Car Subwoofer Logo
    157 people viewed this question
    Top Performance Teknique Car Audio & Video Experts
    hoyzee1
    Joe Alexander
    Joe Alexander
    George Nalley
    Level 1 Expert
    Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
