Question about Logitech R-10 Computer Speakers
More R-10 Thanks Noggin! It's R-10 Speakers, Model No: S-0152B1 (Input:9V 700 mA. :-)
  • 1 more comment
  • Damianjedi Mar 14, 2008
    No matter which port I use these speakers will not work on my e machines:windows xp
  • subhni Jan 03, 2009
    my r-10 speakers do not work .when i put headphone in the headphones place it turns on it works only for a few minutes
  • Julieann Fayhee Mar 08, 2009
    i have the logitech r- 10 speakers model # s-o152A1
    they quit working recently headphones won't work either when plugged in
  • 944 Answers
Found them at last - they do exist! http://www.logitech.com/index.cfm/products/details/US/EN,CRID=2173,CONTENTID=9817 try this next page (near the bottom): http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7&p_created=1083624908&p_sid=NbWLjZvi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**&p_li=&p_topview=1 It appears that there is no associated software specifically for these speakers, they are a simple jack connection type - if they work on your walkman, but not on your pc then: the jack is either plugged into the wrong hole,or the volume is down in windows or in the application you are trying to hear or both (or on any special non-windows soundcard software).(ask again if you are unsure how to check this). Make sure your soundcard works by plugging in some headphones or speakers you know work. the only other thing i can think of worth checking is if you have used the headphone jack in the front of the speakers - this will cut the sound to the speakers by way of a small spring contact - sometimes this can get stuck open, but obviously not if they work on your walkman. maybe a bit of dirt got in there - just plug another jack in a couple of times to check. Also check if the volume control works fine when plugged in your walkman. Hope this gets you sounds :)
Posted on Mar 07, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 07, 2007
    also just thought - check that the power supply is getting enough juice when plugged in next to your pc if this is different from where you had them working. sometimes on big multi-adaptor banks you can underpower a speaker set, but these are small enough for this problem to be unlikely.
I had same prob went into control panel go to sounds and devices and make sure your speaker volume is on! I felt so relieved and dumb hope that helps!!!
Posted on Feb 13, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Can I use a power plug that is input 120vac,output 9v on a sound monitor ? the ML699 hifi sound monitor
I am guessing the speakers do not list their power requirement. 9v should be low enough to test if it works without damaging them. The yamaha speakers I have use 14v.
Mar 04, 2015 | Computers & Internet
Keyboard AC Adapter
If thje voltage is the same, the current rating is fine at 1000-1400 mA. The accessory will use the amount of current it needs and the fact that there is more "available" does not mean it will use it. The higher current rating will not ruin the equipment. Just make sure the voltage rating is the same. Cheers!
Mar 09, 2014 | Casio AD5 Keyboard AC Adapter
MARANTZ MA 700 NOT SURE HOW TO MAKE CONNECTIONS. NO MANUEL. LIGHTS UP
you'll want to use the rca sub out from your pioneer, to almost any input (aux, tape, cd) of the marantz, then speaker cable from marantz to sub. once you get them hooked up, adjust volume, bass, on the marantz to blend well with main speakers at a nominal lvl,
Mar 20, 2013 | Audio Players & Recorders
Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Nov 02, 2011 | Creative Labs SBS 370 Computer Speakers
Please tell me the input voltage and amperageof my speakers emachine model sp-30a
Output Values:
Output 9 VAC 200 Ma
Input values:
Input 120 VAC 60 Hz
I believe this is what you are looking for. Output voltage and amperage for the SP-30A speakers, as read on the tag. The output will be the sound out and capabilities. The input is going to be the standard US wall socket.
Apr 26, 2011 | Audio Players & Recorders
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I need a new voice coil and entire cone and surround replacment for my ma audio 2002 model ma100Xl 10" subwoofer. any Suggestions?
MA does not make a recone kit, and does not repair out-of-warranty equipment.
You have a door stopper i'm afraid.
Thanks for using FixYa!!
Sep 30, 2009 | MA Audio MA 100 XL Car Speaker
Power cord
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
The power cord is
Input: 120V, 60 Hz.
Output: 9V AC, 400 mA.
So , there is no need to worry about Polarity here. Just make sure , the output voltage is around 9V. DC input is ok. since there is bridge rectifier inside.
Aug 17, 2008 | AT&T 1717 Digital Answering Machine
Hardware not found
do you have any more part numbers or serial numbers on the speakers - there doesn't seem to be a "r10" that i can find - was hoping Z10 stuff might work. Let me know any more info you have and i will try again. :)
Mar 07, 2007 | Logitech R-10 Computer Speakers
Logitech R-10 Computer Speakers Logo
401 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
