Test failing what does this mean
I have been trying to reformat my laptop but have been unable to get some drivers to install. I have a dell and am running vista. I began running tests from diagnostics and everything passes until it gets to the SATA Disk. They all fail. Tell me I can recover this and I don't have to replace my harddrive. If I can recover this how. Please advise.
  • La Von Beckstead
    La Von Beckstead Dec 12, 2008
    Well I won't rate you bad for telling me what I thought already. I appreciate your response and your help thanks so much
    President:
  • 1,314 Answers
Sorry to be the bearer of bad news and please don't give me a bad rating for this but unfortunately you do need to replace the hard drive. Chances of you recovering the data depends on what is failing in the hard drive. You can hook it up as a data drive once you get the replacement drive up and operational and see if you can extract your data off of it.
Thanks and please take a moment to rate as fixya.
Posted on Dec 12, 2008
Dell 1558-2182 boots about 1-3 hours. It hangs on screen "Welcome" for 1-3 hours. Safe mode runs ok When I try to log on guest account laptop reboots When I run PSA (Pres-boot System...
before changing disk, you can try reformat and re install.
The disk may be okay and you are having windows problem especially
because safe mode works okay.
Aug 03, 2011 | Computers & Internet
I have a major problem, and hope someone can help me before i've gone crazy. ='( i reformatted my newly purchased laptop and made it to windows 7 ultimate extreme 64bit,but when i'm about to install the...
- Reformat the drive and install Windows 7. - go to this site - http://support.dell.com/support/downloads/index.aspx?s=dhs&cs=19 - Enter the Service tag which is printed bottom of your laptop, then it will redirect to the correct driver page - select the operating system. - Install major drivers first (Video,Chipset then Audio, Webcam etc)
this should work fine - Dont get panic... you can do that.
Mar 04, 2011 | Dell Computers & Internet
My laptop doesn't read my graphic card after i reformat it.
some laptops have special kind of driver for specific models. try going to support.dell.com and look for the model and video driver for it. download it and install it in your computer. but make sure you install the chipset driver first before doing so.
Feb 07, 2011 | Dell Computers & Internet
I have two Dell Latitude Laptop C500/C600 exhibitting the same problems with detecting the primary Hard Drive. The drives show up in the Bios (I have tried several drives, all pulled from other working...
if hdd is detected in the bios but cannot be detected when booting to windows then do this.
1. turn off laptop, press and hold on the Fn key then press power button once
2. psa test will run and check if it shows your error codes such as 0141 - 0142 - 0146 this means hdd needs replacement.
Oct 14, 2009 | Dell Computers & Internet
Dell inspiron 1525 w/ Vista 32 will not hibernate
Hibernate issues are generally an issue with the Video driver. Try the following: Update to the latest list of drivers from support.dell.com BIOS Video Driver see if the issue is resolved. If not, then try editing the startup group of MSCONFIG and see if an item running at startup is causing the issue. (Start, RUN, MSCONFIG, OK to open MSCONFIG)
Jun 09, 2009 | Dell Inspiron 1525 Laptop
Failed DST Short Test and Screwy Mouse/Keyboard
Hi there.
I'm sorry to say that error code 1000-0146 means that the hard drive is failing and it can go at anytime, get yourself a USB mouse and start the computer up, the operating system should recognize the mouse and install the drivers (it may take a couple of minutes so be patient), as soon as the mouse is installed it is imperative that you back up all of your data, either to an external drive or CD/DVD.
Then you have to purchase another dive of if you have any warranty on the laptop send it in for Dell to repair.
If you are out of warranty and need instruction on how to install a new drive please feel free to post back.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Dell Inspiron 6000 Notebook
Unable to connect to internet
Hi.
What do you mean by "reloading Windows"? Did you repair it? Maybe did reinstallation? If so, you may need to install drivers for your Ethernet adapter. You will need to specify Ethernet adapter manufacturer and model (if it is onboard adapter, then motherboard manufacturer and model), so I can provide you with the download link, in case you don't have the drivers.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
Problem with dell inspiron 6000
Reformatting drives cleans up your disc. Or shall we say when done reformatting, you started from scratch. That is if you install a fresh copy of Windows. Now, doing that, you should reinstall all the drivers needed for your laptop to have the functions working again. Your screen resolution matter, it can be 1280x800 again if you install the graphics driver of your laptop. To avoid this kind of problem again, you should install updated full version of antivirus.
Jan 07, 2009 | Dell INSPIRON 6000 CENTRINO...
Wireless network adapter not recognized after reformatting
http://support.intel.com/support/wireless/wlan/sb/CS-010623.htm
go here and follow the steps to get the drivers and software to install.
dont know what o.s. you are running, but go into device manager, if you haven't already, to see if the apropriate drivers are installed and are enabled. let me know.
Dec 22, 2008 | Intel PRO/Wireless 3945ABG Network...
Dell Inspiron 5150
This can be caused by a bad memory chip, but most of the time the hard drive has failed or bad sector that it's unable to read from. If your machine has a diagnostic or hard drive test in the bios, run it. Some also have a memory test that you can run. If yours does have these and any part of the hard drive or memory test fails, the there's your problem. If you don't have these, the start by removing the memory and trying them one at a time. If this doesn't work, then reformat the hard drive and reinstall the operating system. If you have any problems during or after the format and reload, then the hard drive has failed and will need replaced.
Jul 24, 2008 | Dell Inspiron 5160 Notebook
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
