Question about Whirlpool RBD305PD Electric Double Oven
Top oven won't turn off
My cleaning lady sprayed the top oven with Easy-off. She did not heat the oven, just shut the door, waited an hour, then opened the door and wiped it clean.
I was not home at the time. :( When I got home, the oven was making noises like it was cycling heat, but the control panel showed only the time. When I opened the door, I was hit with a blast of heat. The only way to turn off the heat was to turn off the circuit breaker.
I have tried wiping down the elements while the oven is cold. I have tried adjusting the elements, to no avail.
Can you help?
  • Anonymous Mar 23, 2014
    How to wipe the top of the inside oven after pyrolytic process
  • 71 Answers
The problem is the high voltage relay which might be on the control board or on the back of the oven . the contacts on the relay are most likely fused together check with a ohm meter.
Posted on Dec 12, 2008
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Oven door will not open after self clean
There are two easy things to try to fix this.
First, unplug the oven, or turn off the circuit breaker to it - so long as power is cut to the oven. Leave it for about 5 minutes, then plug it back in or turn the circuit breaker back on and try to open the door.
If that doesn't work, turn on the self-cleaning cycle again, and let it run for about 15 minutes. Then turn it off and wait another 15 minutes, and see if the door will open.
If neither of those work, you have a more serious problem with the locking mechanism. Either a bad solenoid or a damaged heat locking mechanism. Both of these will require removing the stove top to access and repair. Let me know if the above suggestions fix the problem. If they don't, I will get you more specifics on repairing the locking mechanism - assuming you're up for that.
-Dyllan
Mar 06, 2008 | Ovens
My husband sprayed the non-fume Easy-Off oven spray into our KitchenAid self-cleaning oven. Then turned IT ON TO CLEAN! It was on for about 1/2 hour. There are instructions all over the can NOT to turn...
The best thing to do is with a cold oven, go ahead and use the Easy-Off non fume again and wait 2 hours. This should remove the original grease as well as the left over Easy Off from the 1st application.
Jun 05, 2011 | Ovens
All I want o know is how to clean it. I think it's a basic question that should be on line with out having to type a thesis to you. I have a day where I can clean it Now I have to wait for your...
Instructions Things You'll Need:
  • Oven Cleaner
  • Soft Rags
  • Sponges
  • Oven Cleaner
  • Sponges
    Self Cleaning
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  4. Fast Cleaning
  5. Remove oven racks and place them in soapy water to soak.
  6. Preheat oven to 200 degrees.
  7. Turn the oven off and spray the inside with oven cleaner.
  8. Allow to sit for 10 minutes.
  9. Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. Dry with a soft cloth.
Feb 02, 2011 | Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    How to clean inside top of oven above heating element
    FIRST TURN OFF POWER THEN SPRAY TOP WITH OVEN CLEANER AND LEAVE OVERNIGHT THEN CLEAN WITH STRONG PLASTIC BRUSH NOT A WIRE BRUSH AS THIS WOULD CAUSE DAMAGE , WHEN FINISHED CLEANING WASH WITH WARM WATER ,
    Nov 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
    How to clean in between glass oven doors
    YOU CAN TRY SPRAYING OVEN CLEANER INTO VENT AT THE TOP OF DOOR AND LEAVE 20 MIN THEN SPRAY WITH WATER AND TURN OVEN ON TO DRY .
    Oct 20, 2009 | Ovens
    I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
    most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
    Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
    Oven door won t open after self clean cycle
    Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
    Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
    GE P7 Oven
    I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
    I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
    Good Luck,
    Linda
    Nov 27, 2007 | GE JKP15 Electric Single Oven
    Whirlpool RBD305PD Electric Double Oven Logo
    95 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal De
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
