Question about ViewSonic N1930W 19 in. LCD TV
VGA hookup to my Toshiba Satellite
How can I hook up my VGA cable from my Viewsonic N1930w lcd tv, to my Toshiba Satellite? I have the cords properly in place, but how can I get the proper input on my tv to display my notebook?
  • Anonymous Apr 08, 2009
    I plugged the VGA cable in, but there doesn't appear to be an option to select VGA... wtf?
  • ViewSonic Master
  • 5,218 Answers
Set the TV input to PC (that's ViewSonic's term for the VGA port).
Setting the computer to output to the PC may depend on your OS (XP, Vista). Reboot the computer after connecting the monitor and see if new hardware is found. Reboot again if you have a flickering screen. In Vista, right clicking on the desktop brings up various video and desktop options. Choose Screen Resolution and look for the multiple monitors line. Click Apply and OK after setting your desired output. In the Screen Resolution window you should see two monitor boxes (labeled 1 and 2) if the computer sees the monitor.
If the second monitor is not showing up (no new hardware found), check your BIOS and device drivers to see if you need to enable or update the drivers for the VGA port. Check your manual for the BIOS (often it is click F1 or F2 before the OS loads; it's often tricky timing and I have to try repeatedly). Device manager will have a red x if the port is disabled; the exclamation point (yellow triangle) indicates driver issues.
I realize this is nearly a year after you posted your questions but I hope it will help the next person searching for answers on this TV.
Posted on Apr 13, 2010
Cable
I tried to connect my PC with LCD TV using an HDMI cable.
PC did not detect my TV; however everything works fine with VGA cable. VGA cable is the perfect choice.
Jul 08, 2013 | Toshiba Satellite L305D-S5974 Laptop
Power locked viewsonic n1930w
On the tv itself hold down CHANNEL button and hold the MENU button then press the POWER button, You will get into the service menu. from here I went in to the CARNIVAL menus and changed the PW setting then backed out... Power button worked. Then I went back in and played with everything else... but in the end left everything the way it was in the end. I suggest you do the same. Good luck.
Jun 10, 2012 | ViewSonic N1930W 19 in. LCD TV
Need ViewSonic N1930W repair manual
Here you go http://www.manualowl.com/p/ViewSonic/N1930W/Manual/20267
Sep 26, 2011 | ViewSonic N1930W 19 in. LCD TV
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound)
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/pdf/UX8623D.pdf - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector. http://www.viewsonic.com.au/support/manuals/files/LCd%20TV/N2750w%20User%20Guide%20English.pdf
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
How do i connect my l300 to my tv
Well if you have a newer tv,,that has on the back a computer hookup,,like vga,,,get a vga to vga cable,,radio shack has them,,and maybe other stores,,if your laptop has a s-video out the backl ,,get a that ,,if you dont have vga on tv,,good luck
Nov 20, 2010 | Toshiba Satellite Pro L300 Notebook
ViewSonic VG2021m monitor without installation software
try using the FN "function key" and you should have a button at the top that looks like and LCD press it while holding the FN button
Dec 16, 2009 | ViewSonic VG2021m LCD Monitor
I cannot find hdtv channels on my viewsonic n1930w hdtv monitor, but it does find them on my vizio 22'' hdtv monitor. Am I doing something wrong
Are you trying to get the HD signal from the roof antenna or from cable? when you set the tuner to scan for channels make sure it is set for 'CABLE' if you are on cable, or 'AIR' if using roof antenna.
Oct 31, 2009 | ViewSonic N1930W 19 in. LCD TV
White screen, no picture.
Base from my experience this problem is 75%(BAD LCD) needs to be replaced with new LCD. The rest of 25% is cable connection loose.
Roan
Aug 03, 2009 | ViewSonic N1930W 19 in. LCD TV
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
Need to know how to hook up 32' HDTV with DishTV satellite hookup
It seem that you maybe mistype the model number , take a look there http://www.tacp.toshiba.com/televisions/lcd/product.asp?model=32av50u this tv seems to fit yours , if not look at the other one and go in resources , there you can download the manual for your television , i own a toshiba lcd too and its pretty easy to plug i just plug it behind , use to remote input buttom and that it , just make sure you plugged the satellite dish cable at the good place behind your satellite receiver maybe it could be the problem too .
Jan 25, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
ViewSonic N1930W 19 in. LCD TV Logo
685 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
