Question about ASUS AI Lifestylestyle M2N-SLI Deluxe (ASUM2NSLIDELUXE) Motherboard
M2N-SLI Motherboard issue.
I boot up the computer and of course it is all set to default. So I go into bios, setup time, date, devices, yadda yadda yadda. Go to save and exit. Everything reboots fine until halfway thru post. Then the screen goes black. Only way I can get computer to boot is without the battery. Which boots fine again until I change settings in the bios and then it happens again. Machine only works with default settings and no battery.
Ram is (2) OCZ PC2 6400 Nvidia SLI Ready 1GB Dual Ch 4-4-4 1T
Please please please someone help :(
    Problem Solver:
  • 4 Answers
Hi
If your computer was ok before you changed parameters in Bios then it is Bios fault:
Re inter Bios and Try to reset it to default.
If you can not get into Bios anymore  the problem is serious:
You must reflash Bios or reset Cmos ,and it could be vga or may be the wifi if you have one onboard.
see if you have a hardware store nearby and let someone fix it
if you .
It seems to be a common problem on all Asus Motherboards:
bios,vga,post etc...
Posted on Dec 12, 2008
After instal windows7 the system hangs after several minits
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
make sure your ram modules are seated properly with no dust in there sockets
click start right click on computer select proprties you will see ammount of ram installed and usable ram
also cmos battery is seurely seated with no dust in the socket on some motherboards cmos
batteries are soldered in
computers need power and data to travel through every working deviceand to have a finishing point to work
scroll to bottom toolbar (bottom of screen) right click select task manager applications see
whats running also applications if you see something running that should not click end now
hope this helps you
Sep 26, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Won't boot; now no video
Hi rwbta, from your description it sounds like a bios issue.
The bios only displays: (Press the Delete key for setup) when there is a problem with a device.
(Hard disk drive, video device, over clocking settings, ECT). After resetting the bios (As you have done), display should resume. Since it did not suggest you plug the monitor into the second VGA or DVI port on the graphics card & check for display. Try another monitor, (Just to be sure). If you are running in SLI, disconnect the primary PCI express card (Blue slot) & replace it with the second PCI express card. Boot the system & check for display. No display? Move to the second port on the card & check for display. Still no display? Than it is possible your bios may be corrupt.
You can buy a new updated bios directly from Asus estore online, click this link;
http://estore.asus.com/shop/ There are currently 217 pages to search through in order to find the bios chip for the M2N-E SLI board. (Your board is still under warranty).
You can save time by calling Asus tech at; 1-812-282-2787 & talk with a tech. If you choose to do so please write down the S/N found on the parallel port. The tech will want this & check to see if the board is still in warranty. After a short talk with the tech he or she may include another suggestion or you can just ask for an updated bios chip. In either case be sure to get a case number. The average cost for a bios chip is $5.00 not including shipping. Since this board is still in warranty this item should be free for you. Asus store hours: Monday - Friday 8:00 AM. To 6:00 PM PST, excluding weekends and / or holidays.
Good luck rwbta!
Mike
Nov 21, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus |M2N-E SLI Reeboot issues
Hey, I own the same motherboard and I don't have your problem.
I would suggest trying to update the bios, i think its more of a bios problem / motherboard issue, not windows related.
you can get the newest bios from http://support.asus.com/
Oct 20, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Setting up SATA
You need to enter the bios. Use the M2N-E SLI manual to help make some changes. Start up the PC & begin to press the Delete key every two seconds. Doing this will open the bios. Open you're manual to page 4-29. All four SATA's should be set to Disable. Save & exit the bios. The SATA drives will still function but you should no longer get the screen to setup a RAID.
Enjoy!
Mike
May 30, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
BIOS setup won't allow me to set the system time and date for Asus m2n-sli deluxe motherboard.
dear friend
u try system date with windows time and date and then trun off yr pc and put off yr power cable for 10 20 sec then plug on power then try if system date still not work then changer for Mother boad BETTRY it's 2032 number bettry try this one
thanks for using fixya
jo_chinmay
Apr 03, 2008 | Computers & Internet
Asus m2n-e sli Cpu changed settings on boots up
I could not find BIOS ver. 1302 for the M2N-E Mb. What I do know: Your dual core 4200 showing up as "unknown". Asus says:
This is because the BIOS does not have the relative CPU uCode to support this processor. Please simply update your BIOS to version 0902 or later to resolve this problem.
BIOS 0902 can be downloaded from the link below:
http://dlsvr01.asus.com/pub/ASUS/mb/socketAM2/M2N-E%20SLI/0902.zip
Once you cpu shows up correctly, chances are that your over clocking will work and the bios will stop sending you back to change your settings.
Dec 11, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N E SLI Boot and Audio Problems
I would check if there is an updated BIOS available for your board, as this may help
Dec 04, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Vista ultimate - Second card doesn't have enough resources???
thats 64 bit for ya.. welcome to buggy driver "if they support (beta)it"..
chipset, then video driver.. also vista has UAC issues. right click install as admin. good luck (i dont like vistuh)
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Failure to boot after several hours of operation
assuming you set the date and time, the error message checksum can refer to incorrect memory timings along with the front side bus speeds, so check the processor bus speed eg 533MHZ or whatever and check the memory speed as if they are different you wont get it to boot, you will need to reset the bios if you cannot get it to run at all.
Sep 09, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS AI Lifestylestyle M2N-SLI Deluxe (ASUM2NSLIDELUXE) Motherboard Logo
111 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
