Question about Performance Teknique ICBM-5712 Car Subwoofer
I need rms spec's for performance teknique CBM-5712,
I have a pair of performance teknique CBM-5712,im trying to find the spec's on RMS,it just say it gives out 500 RMS but it also say its 2/4/8 ohm operational,so im trying to see the best way to wire them and how much power would it get if i wire them 2/4/or 8 ohm.just want to know my options.thank you
  • 104 Answers
You will get more power at lower ohms, the lower the ohms the less resistance it will have against the amplifier
heres a small definition if it helps
The ohm is defined as the electric resistance between two points of a conductor when a constant potential difference of 1 volt, applied to these points, produces in the conductor a current of 1 ampere, the conductor not being the seat of any electromotive force.[
Posted on Dec 15, 2008
Whats the RMS Watts on a Performance Teknique ICBM 5910 I know it has 1500w peak but I'd like to know the rms watts on the subwoofer
Personally, I would not put more than 500 RMS total to that sub. 300-400 RMS is more like it.
Jan 05, 2014 | Car Audio & Video
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Whats the specs
    • Bridged Max Power: 520 Watts
    • RMS Mono: 170
    • Variable Low Pass 40Hz-120Hz
    • Variable Hi Pass 150Hz-1.5Khz
    • THD: 0.02%
    • Die-Cast Aluminum Heat Sinks
    Sep 20, 2010 | Power Acoustik XL2-520 SPL Car Audio...
    I have a pioneer XL2-520 amplifier. I bought it used. So I didn't get the user manual and the sticker on the bottom of amp is not there.. So I was wondering how many watts (rms) in mono mode at 2ohms....
    i think its a power acoustik amp im not sure that was a pioneer model. if it is apower acoustik the specs are
    125 rms x 2 @ 4 ohms
    150 rms x 2 @ 2 Ohms
    300 rms x 1 @ 4 Ohms
    You can only bridge the amp at 4 ohms dnt go lower than that
    Sep 13, 2010 | Car Audio & Video
    Ok...im getting a speaker that has an 8 nominal load and 600W peak 400Wprogram and 200W RMS...two...what is RMS and what kind of amp do i need so that i dont get screwd over. thank you bunchesand also i...
    RMs is the average power (really basically) > You need to get an amp that is around 150W - 180 WRMS. You need to be really specific about the rms. Dont let guys tell you 1000 W peak etc. Peak is term that can often have several meanings, but true RMS is the norm standard for assesing proper power in pro gear. Whatever you find check out the specs for yourself in writing!!!
    Hope it helps
    Jul 26, 2009 | Audio Players & Recorders
    I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
    Hello perezmagdiel,
    That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
    Hope this helps.
    Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
    I got a performance teknique power amp its 1700 rms at 1 ohm i need 1500 rms at a load of .67 will be ok
    No, with 1700watts at 1 ohm the max current is 41 amperes, with 1500 at 0.67 the currents is almost 48 ampreres, you will be overdriving the amp at signal peaks.
    Apr 08, 2009 | Performance Teknique ICBM-782 Car Audio...
    Im trying to find RMS specs for PERFORMANCE TEKNIQUE CBM-5712 SUB
    WELL FIRST IF THEY ARE DUAL VOICE COILS, IF SO,TO GET 2 OHMS JUS THOOK THEM UP TO ONE OF THE TWO TERMINALS, IF YOU WANT 4 OHMS HOOK YOUR POWER LEAD TO ONE TERMINAL THEN ABOUT THREE FEET OF WIRE COMING FROM YOUR LEAD TO THE O9THER TERMINAL, IF YOU WANT 8 OHMSHOOK YOUR POWER LEAD TO + ON ONE SIDE THEN THE NEGITIVE LEAD TO THE - ON THE OTHER SIDE, THEN VISE VERSA. BUT IF I WHERE YOU MAKE THEM 4 OHMS
    GOOD LUCK
    Dec 12, 2008 | Performance Teknique ICBM-5712 Car...
    Performance teknique ICBM-5612
    Whats yhe Rms on this sub? Which is better compared with the 5712 modle?
    Mar 22, 2008 | Performance Teknique ICBM-5612 Car...
    Performance Teknique ICBM-5712 Car Subwoofer Logo
    105 people viewed this question
    Top Performance Teknique Car Audio & Video Experts
    hoyzee1
    Jose Velazquez
    Jose Velazquez
    George Nalley
    Level 1 Expert
    Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
