Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Gas controler valve does not open up for lower bunner only
When i tap the valve the burner will work . is this fixable
  • dkelley Dec 12, 2008
    Thank you very much D Kelley
    Scholar:
  • 162 Answers
The valve that you are taping is the safety valve, that's what needs replacing, that's how i test them. they can not be repear. they seld them brand new.
Posted on Dec 12, 2008
My Coleman furnace 4322/729 model lights the pilot but won't cut in . What could be problem ? Cleared lines Complete
Gas valve not opening? Does it have the exhaust blower that pulls vacuum switch allowing burner to light?
(1) Thermostat not working? Has to complete the circuit in or gas valve to open.
(2)Can be a stuck or bad gas valve. Try tapping the side of the gas valve body while thermostat is calling for heat. Tapping,not pounding. Like lightly,yannow? don-ohio (:^)
Jan 03, 2017 | Coleman Heating & Cooling
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
May 18, 2015 | Kitchen Ranges
My ignitor works but not the bunners
The draft fan is supposed to come on then the ignitor comes on then after 30 seconds the burners supposed to ignite. At that point you should check and see if voltage is being sent to the gas valve solenoid. If you getting volts there with the glowbar on then you need a new gas valve unless you forgot to pay the gas bill.
Oct 29, 2011 | Ruud UBHC Air Conditioner
Maytag Prec touch 750 lower oven takes too long to preheat
This is a common problem that happens when the oven gas control valve is sticking. This can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 23, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
Have igniter, but no flame.
Ok first thing you need to verify is that the gas valve is on at the connector and there is gas pressure. Then verify that there is no restriction on the flexible gas line(kinked) or any PTFE tape or pipe dope stuck in the connection restricting gas flow. Then make sure that the appliance gas regulator is installed in the right direction and not installed backwards(if it is backwards you will get no gas). Also you might find a valve located on the regulator called a runaway valve(looks like a small clip) is off. Verify that the run-away valve is on. This valve will **** off gas to the oven burner. Then verify that there is no tape or debris covering the burner orfice or assembly. And when the burner igniter is glowing brightly try giving the gas control valve a tap(it might be sticikng). If it lights after you tap it re-try the oven several times to make sure it is working.
Nov 26, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
Dometic 2811 gas/AC refrigerator poor operation on gas mode.
Your gas valve is sticking. Could be a bad thermocouple.
Set it to come on, then with a screwdriver handle or something similar, tap,tap,tap gently on the gas valve to see if it lights.
Once it unsticks it should operate OK.
If it does not unstick, replace the gas valve.
May 26, 2009 | Dometic Refrigerators
The oven won't light.
jeff, i read your other ? here and i think you probably have a weak ignitor. does the ignitor glow orange?
if it does, or i should say when it does, just tap lightly on the gas valve and see if that causes the gas to flow into the burner and then light.
you can use the handle of a screwdriver to tap with and it wont need to much force.
if this does work, then just replace the ignitor. when they get weak they will glow, but wont draw enough current thru the gas valve to allow it to open. your valve does get voltage but it opens when enough current draw opens the bi-metal portion of the valve to allow gas to flow.
if you have no glow, then its a whole different problem. to be addressed in next comments.
Jan 15, 2009 | Tappan TGF320 Gas Kitchen Range
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
128 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
